I just got this from a panw shop, it doesn't work it need a battery and I take it it also need a charger for the battery, where is the best place to get one of each, can I get one from the factory, along...
OK, first it doesn't need a charger. Most charger are external types.
Battery, it probably uses one (1) CR123A which is a three (3) volt battery, or
two (2) "AA" batteries which are rated at 1 1/2 volts each. Batteries you can
get them every where, Radio Shack, WalMart, Kmart, Sam's, Walgreen's, One Stop
Batteries, etc. The average life for the CR123A is about twenty hours of use,
and it probably the same for the double "AA's.
Here how this Famous Trails End NV FT300 Monocular work. The monocular has
two button-one for on/off, and the other is for the IR luminations.
.WARNING!!!! This a night vision devise will be
used at Night! Don't taking a look see at bright lights or using the night
vision devise during the day... Light time.
Now the monocular has a build in shut off for to much light entering the
image tube. Don't try it, it works. The more times the monocular NV is subjected
to bright lights the more it destroys the thinly film cover over the plate. One
it gone, new image intensifier tube and the cost will be about $200 plus
shipping and handling.If you just have to take a look see in the monocular. Get
a couple of optic lens cover that snap on. The front Optic cover drill about
1/16 in hole in the center of the cap, that it. Now you can take the back lens
cover and remove it. Turn your monocular on and take a look through the eye
piece. It should be green, if not, take it back the Pawn Shop and ask for a
refund.
If you don't have lens covers that OK too. Just get in dark room and point
the monocular at one of the corners. Don't point it any lights. It will turn
green. I will advise you don't test the auto shut off. You don't know who had
first, second or even third time, how it was handed and used. stewbison
