Rolex Submariner 16618 Wristwatch Logo
Posted on Jan 22, 2010
My Rolex that I have had for 9 years keeps stopping when I thake it off. I have to shake it for it to start again.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
4334
Points
11
Needs service, clean and oil.
1helpful
"Rolex oyster perpetual dateadjust" stops once in 2 days or less. starts on shaking the hand. advice?
try winding by using the crown see how long it goes for it may be the bob weight is not working or as come loose
My three-year old (real) Rolex Oyster Perpetual Lady Date Just started losing time after just six months. It would stop and start intemittently and lose a few minutes every hour. Winding did no good. I...
It seems to me that the company servicing your timepiece (Rolex or otherwise) must have missed something or did not properly service your timepiece.
You are correct that your watch should not require service every ten months. After servicing, your Rolex, like most all automatics, should run properly for 3-5 years depending on environmental conditions. Our Rolex service offers a one year warranty, and if any issues present within that time, the service is free.
I would recommend using a company that has a full time Certified Master Horologist on staff to service your timepiece that offers a warranty on their work. Thanks for the rating, and we are happy to help you and service your Rolex.
http://www.watchandpen.com/id76.html
Expert watch repair for Rolex Breitling Tag Heuer Movado
I usually shake my Rolex (Datejust Oyster Perpetual) because it slides to one side, but when I shake it, the second hand sometimes stops. Once I shake it again, it begins to tick again. I have tried...
What's the question? From you description of the troubles you are having I suspect that your watch may on the outside look like a Rolex, but it certainly does not behave like one. I have never had such erratic behavior even with my much cheaper, but authentic Casios.
My Rolex Explorer (black face, hacking model) is suddenly losing time and briefly stopping. Something inside rattles when I shake the watch. Can you suggest a likely diagnosis and rough price to hav
It's a very small timing gear, will roughly cost about 60.00 to fix it, has to be taken down part of the way to be put back into place, very common for them to pop loose
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
I have a 1992 Rolex DAteJust- it runs great for several weeks .. of everyday use, and then it will stop for no apparent reason. After I shake it a few times.. it runs again.. but it seems that it...
Nail on the head. Take it to a good repair/service shop that does Rolex service. Know this, it wont be cheap. But you will get the watch back in great condition and it will run perfect.
Stops after i take it off, I have to shake it to get it going again, problem is intermittent, I have no clue...
Your watch is self winding and will run down (if fully wound) for about 2 days.
This type of watch thrives on use and if not used will stop. To avoid having to re-wind by shaking, it should be worn every day.
(Some makers say that to full wind up their self winding watches, they need to be shaken (gently) aboiut 200 times).
1helpful
Keeps stopping even when i am wearing it on my wrist.
Your Rolex sounds like it has a problem with the automatic winding gear train.A Rolex needs regular servicing when parts can be inspected and replaced.Servicing is about 3-5 year intervals.
You need a specialist Rolex watchmaker as only they can obtain Rolex parts.Try www.rolexrepairs.co.uk a full service will take 2-3 weeks.
My Rolex Sub that I have had for 9 years keeps stopping. I have to shake it for it to start again
If you haven't had it attended to since you bought it, then I suggest that it might need a clean.
Rolex will advise you if there is any other attention needed.
2answers
My rolex jz stopped moving.
AS I'm sure you know, when changing the time (presumably by pulling out the winder), the watch stops.
Normally the watch re-starts when the winder is returned to the "in" position.
Check that the winder is fully home.
If it doesn't start, pull the winder out and in again. If necessary try this several times.
If this does not solve the problem, then a visit to Rolex may be necessary!
30helpful
5answers
Rolex ad Daytona 1992 replica
The advice given here is accurate to a degree. When wound, a rolex daytona IS running. However, it is the running seconds hand in the small sub-dial that is actually running. In the earlier Daytonas, this sub-dial was at the 9 o'clock position on the dial, (pre-2001 series daytonas). The later daytonas, from 2001 on, use the seconds at 6 position for counting seconds. The main sweeping second hand on the watch dial will NOT start until activated by the pusher at the 2 position. That pusher needs to be unscrewed and then pushed to start the large sweeping second hand. This action, in turn, starts the remaining 2 sub-dials in motion, counting minutes and hours. To stop the chronograph function, you push the pusher @ the 2 position again, to stop the sub-dial hands from counting, and then push the pusher @ the 4 position to re-set the dials to their "straight up position". This stops the chrono's function, until it is needed again, BUT the main running seconds, (at either the 9 or 6 sub-dial position, depending on the year series of the daytona) will continue to run, thus keeping accurate time.  Hope this gives you a better idea of how the timekeeping of the chronograph function on a Daytona works. So, to start your seconds running you need to start the chrono function by pressing the pusher at the 2 position. That will allow you to see the large sweeping second hand I think you're referring to here. Hope this has helped.
Doug
Top Rolex Watches Experts
NOEL
NOEL
john h
k24674
Are you a Rolex Watch Expert? Answer questions, earn points and help others
