Televison & Video Logo
Anonymous Posted on Jan 22, 2010
LG CRT TV, picture becomes yellowish
I own LG CRT TV, model is 21FB5RLX-ZV. After I turn it on picture is OK for a few seconds but then it becomes yellowish. Also sometimes while TV is on colors become normal for some time so I suspect bad solder somewhere.
  • 1 more comment
  • Anonymous Jan 22, 2010
    I already tried to resolder whole board attached to tube but problem remains. There is only one chip there TDA6107AJF/N1. Now I didn't suck away old solder and put new but only heated solder joints until melting point, could that be problem?
    Tried resoldering it with new solder, now when I turn TV on colors are OK but now after a few seconds screens first becomes redish then greenish and in the end yellowish and it all happens within few seconds. Is it possible that the chip is damaged?
    thx
  • Anonymous Mar 29, 2014
    phillipa crt tv 27pt
Girish Bhat
Level 2:
New Friend:
  • Expert 106 Answers
  • Posted on Jan 22, 2010
Girish Bhat
Expert
Level 2:
New Friend:
Answers
106
Questions
0
Helped
21408
Points
203
Yes it is due to dry solder in vedeo driver section(a board fixed to the pict-tube.).
  • Girish Bhat
    Girish Bhat Jan 24, 2010
    plz change the picture tube base... or u have to look screen settings in lot...i mean adjust...otherwise the chip may be having problem..ok
samuel
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on May 10, 2015
samuel
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
2000
Points
5
When the picture became yellowish after some minutes replace the tube base socket
My sharp tv model 20V-J100M,,when i turn on green light present but in a few second comes to standby
ba coil around picture tube called as "yoke" is problem sum in ur tv... when copper coils become rusty or cut such problem will come in sharp tv's...
Lg display yellowish
your vga cable has broken twist it if works otherwise you needs to replace vga cable
Yellowish picture everything else is good
That model had lots of problems, it sounds like your loosing blue. Try putting up a color bar chart and see if you have blue. Color bar is availible on most cable systems. ggod luck
2helpful
2answers
CRT monitor becomes yellowish..
When any dust goes inside your monitor .......you will get these things.......... remove it , it will work fine
My Benq monitor model V772 turn yellowish occasionally
To solve the problem on my monitor i did a thorough inspection on the pcb which is fixed on the tube and i solder components which looked suspicious for dry joints.
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
