SE refers to a sensor error, remedies include checking all connections plugs: § The connector (5pin, male, white) in the Wire Harness is not connected to the connector (5 pin, female) of Hall Sensor in the MOTOR. ?_? reconnect or repair the contact in the connector The electric contact between the connectors (5 pin, male in the Wire Harness and 5 pin female in the Hall Sensor) is bad or unstable. ?_ Reconnect or repair the contact in the connector ? The connector (6 pin, male, natural) in the Wire Harness is not connected to the connector (6 pin, female, natural) of PWB ASSY(Main) or the electric contact of connectors is bad/unstable. ?_ Reconnect or repair the contact in the connector ? The electric contact between the connectors ¡a6 pin, male in the Wire Harness and 6 pin female in the controller(Main)¡bis bad or unstable. ?_ Reconnect or repair the contact in the connector ? The Wire Harness between Hall Sensor in the MOTOR and PWB ASSY(Main) is cut(open circuited). ?_ Repair/replace the damaged WIRE HARNESS ? The Hall Sensor is out of order/defective. ?_ Replace the Motor ? The controller(Main) is out of order/defective. ?_ Replace the PWB ASSY(Main)
I am having the same problem with my sh**box front loader, same model and fault! Apparently this is a motor sensor fault which is an input/output from the mother board to register the speed of the motor. Either could be faulty, but there is no tech support for this rubbish to narrow down the diagnosis so competent people like us can replace the parts. Service mechanics are a rip to come and repair it and so are the parts! Chuck it down the tip like every other peice of faulty technology! If you get a positive answer please let me know. Cheers
and the motherboard is epoxied so impossible to repair
