Dell W3000 30 in. HD-Ready LCD Television Logo
Posted on Feb 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black horizontal lines
I have a dell lcd w3000 bought 2004 when tv is on it has horizontal lines I try to adjust with the dell program what it does not show is there any hope for this lcd. I have seen other complain about the same issue it seem that noone can resolve this problem. I spent $2000 + I will appreciated if you could tell me what to do with this issue . I don't want to have to spend $1000 to have it fix if I could just buy whatever part it need and install it myself. Thank you
Anonymous
Level 2:
Champion:
  • Expert 206 Answers
  • Posted on Feb 13, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
206
Questions
0
Helped
49310
Points
447
Afraid all the news will be bad. Sound like the panel has failed and no adjustmet will fix this. The panel must be replaced and being it's a Dell a huge brick wall comes up. Dell rarley stocks replacment parts after the production line ends, second they do not want to sell these and third they realy do not want you working on them. Here at my shop we have been in biz for 56 years have all the qualifications to be a warentee station for all the major products and have several tech degrees in computer, monitor and tv repair and we can not get them to couf up a part or even a part number for the product, afraid the only way this can be fixed is to send it to them
Dell w3000 no green power light unit will not power on
This was a product malfunction with that TV. Dell ended up paying out $$ in a class action suit over this product...I think I got a check for like $30 in the end. There is no fix I was told...but try to toggle the master switch, or unplug and plug in again - that often times worked for me. In the end I bought a new tv though because the frustration level was too much.
4answers
Dell w3000 has green power on no video just audio only
Firstly i would suggest you to perform Self-Test Feature Check (STFC)
Your LCD TV when used as a computer display through DVI and/or VGA connection provides a self-test feature that allows you to check whether your LCD TV is functioning properly. If your LCD TV and computer are properly connected but the LCD TV screen remains dark, run the LCD TV self-test by performing the following steps:
  1. Turn off both your computer and the LCD TV.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital(white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the LCD TV.
  4. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the LCD TV cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually
This box also appears during normal system operation if the video cable becomes disconnected or damaged.
Turn off your LCD TV and reconnect the video cable; then turn on both your computer and the LCD TV.If your LCD TV screen remains blank after you use the previous procedure, check your video controller and computer system; your LCD TV is functioning properly.
OSD Warning Messages
A warning message may appear on the screen indicating that the LCD TV is out of sync range.
See Specifications for the Horizontal and Vertical frequency ranges addressable by this LCD TV. Recommended mode is 1280x 768 @ 60Hz.
_____________________________________________________
Thanks for using fixya technical support. You have a wonderful day
2answers
W3000, power and audio but not picture
Yes I tried it and now I have nothing, not even a green light. So much for that. I have 2 of these sets. If you never unplug them from 110 I never have a problem. Un plug them and wait 2-3 days and nothing.
Any lawyers what to take this on?
1helpful
2answers
2answers
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dell tv w3000
Try turning the master power on and off a few times. Give it a few secs inbetween power offs and that should work. It's worked for me. Sometimes it takes longer that other times to show a picture.
Power want come on tv
Yes, I believe it is a power supply issue.... Problem is, I can't locate one
W3000
It's repairable, sounds like the main board, but try some other cables and sources to see if the same thing happens
Top Dell Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Paul Bade
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
