Question about Samsung YP-K3 MP3 Player
My samsung YPK3 mp3 player is fully charged and when I go to turn it on, it freezes on the loading screen. I tried the reset button, but it didn't do anything except turn it off.
    New Friend:
  • 92 Answers
Try to remove all the music on your mp3 player, copy it on your computer so you can put it back later,
after removing all the music try to open it, then if your mp3 player loads completely turn it off then put back the music files
hope this thing helps?
Posted on Jan 22, 2010
SOURCE:
I can't turn it on, the screen only turns on when its plugged in, and it is fully charged. I've also pressed the reset button and nothing happened.
This is common issue with the model of this MP3 Player. You can send it in to Samsung as long as it is still under warrantee.
Samsung's support number is 800-726-7864
Mar 07, 2011 | Samsung Yepp YP-T7JZ MP3 Player
Mp4 player freeze
if you can still see and detect it with your pc there may be a newer firmware update to fix this issue try and find the firmware and flashing utility from the manufacturer and see if that helps
Sep 24, 2009 | Digital Mind Corporation iQ Sound...
Loading Problem - Results in Frozen Gray Screen
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Updated using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 13, 2009 | Philips GOGEAR SA6045 MP3 Player
I can't seem to turn on my Samsung YP-T7J MP3 Player
on the bottom of the mp3 player there is a very little button that u need a needle to push its the reset button sometimes these mp3 freeze and u must push the reset button it u dont loose any music or saved files anything like that it just basically turns the mp3 player off for u so that u can then turn it on using the play and pause button on the side of the mp3 player if this doesnt work the i guess tuff nooges
Nov 30, 2008 | Samsung Yepp YP-T7JX MP3 Player
Wont turn on
poke a pen in the reset button on the bottom back of the player. same thing happened to me.
Jul 14, 2008 | Samsung YP-K3 MP3 Player
Samsung mp3 player YP-F1 screen diplay won't turn on-even when fully charged
I have samsung yepp YP F1. After full charge, it only appear "loading" and somebody told me to reformat the unit. My question is how do i reformat the unit. thanks - - ronnie
May 09, 2008 | Samsung Yepp YP-F1X MP3 Player
YPK3 MP3 PLAYER
try resetting it by pressing the reset hole with a paperclip at the back of the player.
Nov 07, 2007 | Samsung YP-K3 MP3 Player
My mp3 player frooze
Have you tried resetting the player? get a thin paper clip or something similar and push the tip into the hole. then try charging it again untill fully charged, and remove from PC. Good luck
Mar 27, 2006 | Samsung YP-T8 Digital Media Player
Samsung YP-K3 MP3 Player Logo
305 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
