Soundstream PCS-12 Car Subwoofer Logo
Posted on Jan 22, 2010
Wiring diagram for dual voicecoil subwoofer - Soundstream PCS-12 Car Subwoofer
Anonymous
Level 1:
New Friend:
  • Contributor 45 Answers
  • Posted on Jan 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
45
Questions
0
Helped
14990
Points
91
To wire a DVC subwoofer, treat it (in the diagrams) as two seperate speakers, called coil one and coil two. This makes things easier.
To wire them up, wiring them in series would be safer, but if the amp is 2 ohm stable, put them in parallel. Look up dual voice coil wiring in google imagesfor more information and pictures.
2 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jan 10, 2009
SOURCE: wiring of Subwoofer
IF ITS TWO SUBS USE TWO OF THE SAME AMPS AND U WILL GET A BANG
Anonymous
  • 15935 Answers
  • Posted on Jan 15, 2009
SOURCE: How do you wire up 2 4 ohm dual voicecoil subwoofers for 1 ohm?
Both + on Both Subs to + Terminal on amplifier.
Both - on Both Subs to - Terminal on amplifier.
I need pictures on how to wire the dual voicecoils
first u need to know what ohm load the coils are then find out what your amp can be run at then wire then to the lowest load your amp will handle, the best diagram is on rockford fossgate's web site under woofer wiring.
My 12" subwolfer has two ports how do i install it to my amp
if it is a dual 4 ohm voicecoil subwoofer - and your amplifier is rated at a 2 ohm load - both + to the + on the amplifier, and both - to the - on the amplifier will net a 2ohm mono load.
Most amplifiers are capable of a 2 ohm bridged load.
If your subwoofer us dual 2 ohm - a 1 ohm load is achieved, but many amplifiers cannot handle this low impedence and damage will result.
Verify your amplifier's capabilities before wiring - and also the impedence of your voicecoils.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
3helpful
AMP
That amplifier is only stable to 2 ohms.
You will only be able to use one Dual 4 ohm Subwoofer wired in parallel (all + to + on amp.... all - to - on amp.
This will yield a 2 ohm mono load.
It is impossible to wire (2) dual 4 ohm voicecoils to achieve a 2 ohm mono load.
If you're set on using both subwoofers - they will not be getting as much power from your amplifier with a 4 ohm load - but it is your only option.
SEE THIS LINK for the wiring diagram.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
4helpful
2answers
Why does my Legacy LSW157 sub-woofer have 2 inputs?
This is called a dual voicecoil subwoofer.
It gives wiring flexibility.
While playing only 1 voicecoil is possible - it is not recommended.
They should be wired to match your amplifier.
If it is 2ohm Mono stable - you can wire both positives and both negatives together to the amplifier so it sees a 2ohm load (parallel wiring)
If your amplifier is not 2 ohm mono stable - you have no option but to either wire up 1 set of coils... or wire them in series.
+ on amplifier to + on coil1
- on coil 1 to + on coil 2
- on coil 2 to - on amplifier
This will yeild an 8ohm load for your amplifier.
Good for sonic clarity - but you will not get the full potential from your amplifier.
Thanks for using FixYa - A FixYa rating is appreciated for answering your FREE question.
1helpful
15 cvr 4ohm trying to drop to 1 ohm
Are these Dual Voicecoil Subwoofers? Are there 4 terminals on each sub for wires?
If they are Dual 4 ohm voicecoil subwoofers
- connect both + on subwoofer 1
- connect both - on subwoofer 2
- connect both + on subwoofer 2
- connect both - on subwoofer 1
This will give you a 2 ohm STEREO load.
To get a 1 ohm MONO load...
now connect only one of the + on EACH sub to the + on the amplifier.
and the - on EACH sub to the - on the amplifier.
You now have a 1 ohm mono load.
If your speakers are 4ohm single voicecoils (one pair of terminals) the lowest impedence possible is 2 ohms.
This is wired in the same fashion. Both + on the subwoofers to the + on the amp, and both - on the subwoofers to the - on the amp.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
2helpful
2answers
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Orange = Right Positive
Black/ Orange = Right Negative
Yellow = Left Positive
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Trying to figure out what kind of amp i got amercian pro vs-3507?
The VS3507 Is a class D monoblock.
Your optimum wiring for this amplifier is a 2 Ohm load - so it produces its full potential power of 350W RMS.
To Achieve a 2 ohm load, the most common load is one of the following...
(1) Dual 4 Ohm Voicecoil Subwoofer Wired in Parallel.
(2) 4 Ohm Voicecoil Subwoofers wired in Parallel.
(1) Quad 2 Ohm Voicecoil Subwoofer wired in Parallel/Series.
(1) Single 2 Ohm voicecoil subwoofer.
American Pro VS3507 2000W Car Audio Monoblock Amplifier
American Pro VS3507 Monoblock Amplifier Details
  • Built-In Crossover
  • Variable High/Low Pass Filters
  • Phase Shift Control
  • Subsonic Filter
  • Bass Boost Control
  • Dancing Lights at the Rhythm of Music
  • Protection Circuits
  • Gold Plated Terminals
  • Power & Protection Circuit LED
  • 1 x 250 Watts RMS @ 4 Ohms
  • 1 x 350 Watts RMS @ 2 Ohms Thanks for using FixYa - A FixYa rating is appreciated!!
Jl audio 10w6 x zapco350
These subwoofers are dual 4 ohm voicecoils.
Parallel wiring the 2 voicecoils would net a 2 ohm mono load.
Connect both + on the sub to the + on the amp.
Connect both - on the sub to the - on the amp.
Many professionals simply jumper the 2 + and 2- on the sub.... then run 1 set of wires from one of the terminals to the amplifier.
Thank you for using FixYa - a FixYa rating is appreciated!!
1helpful
REWIRE
Series wiring of a 4 ohm DVC subwoofer will result in an 8 ohm load.
See the following diagram.
The diagram listed has a dual 2 ohm voicecoil, netting 4 ohm, however in your case, the dual 4 ohm sub will net an 8 ohm load.
Top Soundstream Car Audio & Video Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
leone C
leone C
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
