The noisy spinning on this model washer is usually the drain pump bearing going bad which could also be a possible cause of the leak. Unplug the washer, Tilt your washer back and rest it against the wall. Remove the belt and manually turn the drain pump pulley, if it is hard to turn either way or is grinding or noisy it will need to be replaced. The leak is a little harder to find. Remove the front bottom and top panels, run the washer, stay back with a flashlight and look where the leak is. If the drain pump is bad it is likely leaking. Next check the center, bottom of the tub for leaks, if the leak is her it is likely the cause of both problems. The tub seal is leaking and has ruined the tub bearing. The tub seals and bearing would need to be replaced. Very involved job, and I would suggest you call a servicer with the expensive tools and knowledge to do the job. There is also a bearing on the bottom of the transmission which could be noisy but would not cause a leak. Hope it is only your drain pump.
Please rate this post. Thank You
