Part number is 651499 at this link and it says it is in stock $27.45
http://www.repairclinic.com/Microwave-Parts?s=t-Maytag+MVH-%3d%3da6c226
Amana / Maytag MVH230W (same same for this model)
Expanded View
http://www.repairclinic.com/SSPartDetail.aspx?s=t-Maytag+MVH-%3d%3da6c226i651499&PartID=651499
I found the same thing at seveal stores. No longer manufactured. Sorry.
There is a fast, if not very elegant solution. Remove the screws and the broken plastic from the two ends of the handle.. Then drill a hole through the front of the handle at each of the screw locations. Buy two 2" flat head machine screws and nuts. With the head on the inside of the door, run the screw through the holes you drilled in the handle. Secure with the nuts on the outside.
As said, not very elegant, but it works fine and saves you from having to replace the whole unit for want of a simple part.
Roger
Here
is a tip that will help you with the online buying...
How to
Buy Appliance
Parts Online
heatman101
