My washing machine had a "nd" code - wasn't draining so I went to the back and tried to see if there was a blockage with the pump and hose. No there wasn't. When I put it back together again and turned it to the spin the spin worked the first time but now the barrel wont spin again. All that happens now is the door locks and NOTHING else. Very frustrating! Please help !
Did you remove the hoses from the pump and look inside the pump.if not you need to remove the pump and look inside it.make sure the electrical connection is firmly in place.them check the hose tha leads out of the bottom of the otter tub and see if there is a piece of clothing or something there.if all this checks out okay replace te drain pump. i sure hope this helps pleases let me knwo how things work for you
I think I need to re-set the machines computer. I turned off and unplugged, but nothing helps. How do I re-set the machine?
