The top!! o-ring inside of thr top plate is bad you need to remove the plate /dissasemble and replace the o-ring
SOLVED! I replaced all the o rings put it together and air jus blew out the exhaust port. I made the mistake of pushing Piston plunger cylinder into the gun till it seated. this left a gap between the head and cylinder. I took the gun apart, removed the cylinder, an reinstalled it only far enough to seat past the o ring gasket. I then installed the head and let the head seat the cylinder as I tightened the screws. this worked on two guns with the same problem. Jn 3:17
SOURCE: Can I use paslode roundrive nails in a Hitachi NR90GC Gas Nailer
Yes, BUT the paslode Round drive nails and known to cause driver jamms due to the excessive paper used in the spacing of the nails.
SOURCE: oiling
Hi Andy,
If you're asking what to oil and when, here you go.
Every day before using it, oil the hammer and slide mechanism. Also put several drops into the hose connector. This extends the life of the seals. You should use a light machine oil.
Hope you find this to very helpful
Mike
SOURCE: Hitachi NR83A air leak
Most all Hitachi nailers that use the plunger style of firing/safety mech will leak air past plunger (part #877-339) when firing, however should not leak when connected to air or resting. If air is leaking past plunger when connnected to air check following:
Remove head to reveal cylinder plate (part#877-318). Remove plate and check outer oring for nicks or broken. If nicked or broken, replace and problem solved. If in good condition, remove cylinder guide (part #877-310) and check two outer orings for nick /cut. Use caution when removing/installing cylinder guide. It is easy to pinch orings when installing causing air leak at plunger. If orings are in good shape then problem is warped body of gun not allowing outer orings to seal. To check for warped body, use the cylinder plate as a guage by lowering it into the area where the cylinder guide rests. Good Luck with your repair.
