HP LaserJet 3055 All-In-One Printer Logo
Posted on Feb 13, 2008
Document loaded my printer showing always document loaded, not copying from glass. Narottam Reply at: [email protected]
  • Anasemona Anasemona Feb 14, 2008
    Hi.
    thanks for your message, but till now you didnt send about my order which is: a Fabrics and Textiles printers, to print direct on differens textiles,if there is also with scanner and screen. and to help of Graphics,or what i mean to be large used for Home and Home Bussines, with full details and prices. thanks alot with best regards. [email protected]
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Feb 14, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
Helped
6739
Points
17
Sounds like the sensor arm in the ADF is stuck in open position. Lift the flap of ADF and see if the sensor arm moves freely.
Jose Imn
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 15, 2018
Jose Imn
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
257
Points
Mis cierto en la tapa del ADF hay un plastico oscuro revisalo
3055 glass
There is no need to change the mode. When the document is loaded on the document feeder, the screen displays "DOCUMENT LOADED" and shall copy or scan this document. To copy or scan from glass, DO NOT LOAD ANY DOCUMENT IN THE FEEDER. The printer will automatically copy / scan from glass.
Can print from computer but page comes out blank when trying to copy a document placed on the glass
In order to copy a document correctly, the document must be facing down onto the glass (text or images facing down), and oriented so that the (typically) top-right corner matches with the triangle next to the glass. Close the lid, then press 'Resume' or one of the buttons labeled 'Start Copy'. This should allow the printer to correctly copy the document.
Thank you for using FixYa! If you require additional assistance, feel free to reply to this solution, and I'll be glad to help you further.
1helpful
How to scan into my computer
Hello, I am happy to help you with your question. Samsung SCX-4200 supplies software calls Samsung Smarthru. This software application includes a scan command. The software is locagted on the CD that accompanied the printer.
Here are some excerpts from the manual:
Your machine offers the following ways to scan an image:
• From TWAIN-compliant software: You can use other
software including Adobe Photoshop Deluxe and Adobe
Photoshop.
• From the Windows images Acquisition (WIA) driver: Your
machine supports the WIA driver for scanning images.
• From the Samsung SmarThru software: Launch Samsung
SmarThru and open Scan To to begin scanning.
NOTE: To scan with your machine, you must install the
software.
Loading document
You can use the document glass to load an original document
for copying and scanning.
1 Lift and open the document cover.
2 Place the document face down on the document glass
and align it with the registration guide at the top left
corner of the glass.
3 Close the document cover. Be careful not to move the
document.
NOTES:
• Leaving the document cover open while copying may affect
copy quality and toner consumption.
So, basically, if you have the software installed. Open the Smarthru software, load your original onto the glass, face down, and close the lid. Select scan, the software may provide you with a preview of the scanned image. Once you scan the document, you must save it to a location on your hard drive, often it is called "My Scans" in your "my documents" file.
I hope that this is helpful. I have attached a link directly to the Samsung website manual for your model
http://downloadcenter.samsung.com/content/UM/200912/20091211171126218/Guide_EN.pdf
1helpful
Does canon pixma mx 310 work faxing page up or page down?
When using the ADF load the document with the side you want to copy, fax or scan facing UP in the ADF.
When using the platen glass load the document with the side to be copied, faxed or scanned facing DOWN on the platen glass.
Trust this helpful.
Please vote.
I can not copy from glass scanner of HP L 7680 all in one, when I load paper into the lid then press copy, printer just load paper in ADF not run copy from glass scanner
Is your system on? If it is on, then you press copy, it scans it and a window showing your scanned document is displayed. Then from here (the system) you can print it. Try it and tell me what happens.
When the Automatic Document Feeder (ADF) to copy I
There are two scan modes when copies are made.When you make copies through ADF you originals go past small **** glass located to the left of the main exposure glass.Any small mark on this **** glass( correction fluid mark,ink mark,small scratch,dust particle and so on)will show as a line on your copy.So to get rid of these vertical lines on your copies you need to clean this small exposure glass.
Problem scanning or copying
Hi BOB
Click on the below link "Solve my problem" for the solution
Solve my problem
Thanks and regard
Rizwan
[email protected]
Black streaks are appearing on printed page when scanning
Do the lines only show up if you use the document feeder? If so, there is something on the strip of glass where the page is scanned. Open the top to reveal the large glass area. Then open the part where the paper feeds in when using the document feeder. It will flip open from right to left. There are two pieces to this, so make sure you grasp it as low as possible. You should see a small strip of glass. Clean all the glass with a SOFT cloth. Don't spray any cleaner onto the glass, rather, spray it onto the cloth if you need any.
4helpful
2answers
Keeps asking to load original in document feeder
This has a happy ending. But first, the obligatory narrative:
The HP site has advice on how to deal with a document feeder that doesn't detect your document. It doesn't talk about the opposite problem, which is what molecular is describing. I had the identical problem yesterday. I'd place the original on the glass and it kept demanding that I put the original in the feeder. So I got into a chat session with the HP technician. Her advice, (based on the possibility that a power surge had created the problem) unplug from everything, restart, and retry. The problem persisted. I told her so. She broke the connection. Nice.
So here is how I fixed it. Using the Setup button>Tools>3. Restore factory defaults, I returned the device to its factory settings. I put the original on the glass and it made the copy without a problem.
Here is a pure speculation. There are at least two ways to enter settings related to two-sided copying. I had used one to enter the settings (two-sided original to two-sided copy, as it happens) and later tried to use another button to change those settings. I noticed the 2-sided settings did not change. I believe the feeder is the default for two-sided copying. So when the system failed to clear the settings, it failed to clear the default. Once I returned all settings to the factory originals, the problem disappeared.
k24674
Grand Canyon Tech
Grand Canyon Tech
