MY WASHER NO LONGER SPINS FROM THE WASH CYCLE AND DOES NOT GO INTO A RINSE CYCLE. IT IS ALSO MAKING A CLICKING NOISE WHEN THE PUMP IS RUNING. SOUNDS LIKE THE PUMP IS NOT WORKING GOOD ALSO
it will drain the water. just will not spin once the wash cycle is complete and then add water for rinse. when i put it in the last spin cycle it will spin the clothes dry.it will drain the water. just will not spin once the wash cycle is complete and then add water for rinse. when i put it in the last spin cycle it will spin the clothes dry.
You can't post conmments that contain an email address.
You have to check your filter for any block. Then put in some water & try to spin it out; if the water does not flow out easily you have to look into your pump, could be a block in there. Refer to user's manual.
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
The typical cycle is; fills to selected water level agitates wash cycle drains wash water spins wash cycle fills to selected water level on rinse cycle agitates on rinse cycle drains rinse water spins final time end of cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it. Good luck!
the top loaders have bad tub seals which allow water on to spin bearing and then gum up everything.take the frount cover and look for water .if so and you have no service contract it will be expensive.aslo google your model to look for re calls
it sounds like the bearings are going out as it spins faster the noise quietens down because the bearings are more spread out and as it slows they fall lower leaving an area that it causing "friction" of a kind
Sounds like the water seal is damaged and the leaking water has damaged the top bearing which is just below the water seal. You will need to have the hub & seal kit replaced.
