Computers & Internet Logo
Posted on Jan 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Window7 crache connecting usb fax modem
My computer turn blue when I connect the modem to a usb port even without connecting phone line. The relay in the modem clicks.
On Windows XP it works perfectly.
Anonymous
Level 2:
  • Expert 280 Answers
  • Posted on Jan 21, 2010
Anonymous
Expert
Level 2:
Answers
280
Questions
0
Helped
118863
Points
811
I expect it is a problem with your USB Driver, Get an updated driver for your USB slots. (either from motherboard manufacturer or USB manufacturer if it is a USB "card")
Even default or old drivers might work Try a few different USB drivers - a new one, the reccomended one, the original one...
(good idea is to use a ps/2 mouse and keyboard since your usb will be going on and off while you're working, it can be hard to click YES when you're keyboard AND mouse aren't working ;-)
if it still dont work...
Can you set any of your USB slots to work in USB 1.0 instead of 2.0, there could be an option in bios, maybe it will run the "OLD" modem in an OLD mode?
Need to hook up a brother MFC-210c so it can fax
Install the software (Brother MFLPro0 relevant to the printer. If you do not have the original CD download the appropriate suite from Brother Solution Center.
When you install the software you will be asked to choose USB, or Local Network. You can always install the USB and connect the printer to the calculator through USB. Different installations for different connection types (USB, LAN)
After you configure the software, you can open the Control Center 3 software and use the fax.
To be able to fax, you need to connect a telephone cable to the port marked line. After you do try pressing the unhook button. If connection to the phone line is correct you will hear the tone.
The MFC can fax without being connect to a computer, just the phone line.
2answers
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
1helpful
Need manual for connecting fax to phone line and computer
Simple:
* one telephone-wire from wall-outlet to port on FAX labelled "line" or "telco";
* one telephone-wire from port labelled "phone" (or an icon of a telephone) to the port on your computer's modem labelled "tel" or "telco" (if your modem has more than just one port).
So, "incoming" telephone-calls go the FAX, to be "answered" by the FAX, while "outgoing" dial-up-Internet connections from your computer's modem "pass-through" the FAX, and to to the wall-port, and further along to the Internet Service Provider.
2answers
How to connect my router without the phone line
since you have a wireless router... you can turn on your wireless connection..try to reinstall it..and proceed to the admin page and turn your wi-fi there...then put password so that you can secure your connection..
after that your computer must have a usb bluetooth device.. you can ask for it in the market...just ask for your purpose...
note: connection of your wi-fi in your computer depends on what is the capacity of the bluetooth device you will buy... i mean it has it's limit in size in transmitting and receiving data...
Connection a Netbook to dial up
You would have to purchase a usb modem, similar to:
  • 71535167228793271903075993308225889520.jpg http://www.avondalesystems.com/images/products/93942447.jpg zoom
  • Fax Modem Usr5637 56k Usb The USRobotics 56K USB Modem delivers the performance and reliability USRobotics is known for, in a compact,…
  • 0helpful
    How to connect the telephone lines
    Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
    i.e is fax line ) or the usb port in the computer ...
    Good luck...
    I need to know how to connect my fax to my computer.
    hi there,
    May i know what is your purpose connecting those unit?
    If you want your computer can dial up internet connection, just plug your phone line to computer modem port and other side plug to the phone port at your fax machine.
    If you want your computer can send fax, same with above tips. but you must install fax program at your computer, so you can directly send fax through your computer.
    br
    3answers
    Setting up linksys adsl2 modem
    The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
    do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
    To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
    1. Connecting the Devices Together
    2. Installing the USB Driver
    Step 1:
    Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
    Step 2:
    Make sure the power adapter is plugged to an available power outlet.
    Step 3:
    Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
    Step 4:
    Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
    Step 1:
    Power on the computer.
    Step 2:
    When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
    NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
    Step 3:
    Click Finish.
    Grand Canyon Tech
    Grand Canyon Tech
