Canon i850 InkJet Photo Printer Logo
Posted on Jan 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon i850 light is green then flashes orange 7 times then goes green and repeats orange flashing. Printer never gets ready
Desktopsbyduck-Computers
Level 3:
Genius:
  • Master 1,061 Answers
  • Posted on May 12, 2014
Master
Level 3:
Genius:
Answers
1061
Questions
0
Helped
351873
Points
2405
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2854
Points
Clean the print head. I ran it under water let it dry n did a nozzle cleaning and presto it worked again.
Robert Kitaji
Level 3:
President:
  • Master 1,335 Answers
  • Posted on Jan 21, 2010
Robert Kitaji
Master
Level 3:
President:
Answers
1335
Questions
Helped
443482
Points
4245
This is a very bad error. It means that the printhead needs servicing and may need to be repaired. There is no easy fix. Sorry.
1helpful
2answers
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
7helpful
Five flashes of orange followed by one green flesh
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
I get a series of blinking orange lights and a green pause.
Hi Mike, the paper feed switch doesn't feed paper... it switches the paper source from the top feeder to the bottom tray. Do you have paper in both? How many times does the orange light flash in between the greens? That tells the error.
Canon i850 not printing
7 times means your waste ink absorber is full, time to let a shop replace the absorbers and reset the counter to clear the error.
Canon PIXMA iP1000 Printer - don't work
GO ON LINE
CANON PIXMA iP1000 7 FLASHING LIGHTS
ENTER
ROD
1helpful
Flashing orange lights
WASTE TANK NEEDS TO BE EMPTIED
GO ON LINE AND TYPE
CANON 850i INKJET PHOTO PRINTER 7 BLINKING LIGHT YELLOW
AND YOU CAN FIND YOUR HELP YOU NEED
ROD THE CANDYMANGNADY
3helpful
S9000 printer will not print.
Hi
Try this see if work for you.
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
8. Your printer should respond as normal.
Operator Error Canon i850 printer
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Will not print
Remove and re-seat the print head. If need be the print head can be cleaned with hot water. YMMV but I've submerged my i850 print head for minutes at a time. Dry it off, blow it out, and it goes right back to work. Common problem if you're using non-Canon inks.
old marine
old marine
ZJ Limited
ZJ Limited
