Please help meeeeeeeeeeeeeeeee my sansa e280 is dead ! that only restart and restart and restart and......... . i try all of your way but i dont take any answer . my sansa restart yet . help help help ............ please.........
i have e250 ant i conect it in DVD and it restart and restart and restart....
i cant start mp3 when i start mp3 show sandisk and restart restar restar
please help mei have e250 ant i conect it in DVD and it restart and restart and restart....
please help me
key how can i fix thisdat thing doesnt work
everytime i try to use it lock the screen
and freezes and then never respondes to the
You can't post conmments that contain an email address.
Try this: Press and hold the center button and the start button at the same time for about 10-20 sec. it worked for, plus thats what the ppl at sandisk told me to do.
Have you downloaded the most recent firmware upgrade?
Does Sansa upgrade software work for you? [Connect with the software running. Turn player on and let the updater take over. When complete, unplug and the device should restart on its own. Once the menus return, I would go to settings and switch to MTP before I did anything else if I were you. MSC is for the updater only. MTP is player (only) mode, I believe.
Please try out this steps. If still have the same problem then try updating the firmware...
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
i would suggest reinstalling the device or removing the device and letting the computer restart to see if that works if that dont work then use the CD that came with the device finally if that dont work contact Customer Support and see if that helps =)
1. turn sansa clip on 2. slide to "hold" 3. press and hold center button do NOT let go... 4. plug in the connector cable 5. wait until computer recognises Sansa device 6. let go of center button 7. drag n drop files and you are all set
if that doesnt work you will need to go to the sandisk website to update the firmware on your device..
let me know if you anymore questions..
Please rate accordingly
Thank you
Computerrep
Try holding the power button down for at least 10 to 15 seconds. That should turn it off. Turn it back on. If this doesn't work, try taking the battery out for a few seconds. If it still comes up with only the blue ring on, called Sandisk tech support to try to get an RMA.
The number for sandisk is 1-866-726-3475 Please rate accordingly Thank you Computerrep
please help me
I have the same problem too.
I disconnect e280 when I am deleting some file .
restat
i bay sansa e250 just two days a go.and now its not working he just restart and restart and restart
my sansa is dead how do i restart it?
