The oven door came off while moving. We have tried everything we can think of to put it back on with no success. Can you explain how it goes back on ?
For normal use of your range, you do not need to remove the door. However, if you have to remove the door follow the instructions in this section.
NOTE: If the door removal pins included in the Anti-Tip Bracket Package are not available, nails or screws may be used. Be careful that the length of the nail or screw does not damage the oven by chipping or scratching the porcelain surface.
To remove:
1. Open the door about halfway. Insert removal pins into both hinge hangers. Do not remove them while the door is removed from the range.
2. Close the door as far as the door removal pins will let you.
3. Rotate the door toward the range. Lift up the door until it stops. Do not use the door handle to lift the door. Rotate the door toward the floor and pull it toward you.
REMOVING THE OVEN DOOR (CONT.)
To replace:
NOTE: The door removal pins you inserted must still be in both sides of the door.
1. Grasp the door on the sides with your fingers on the front of the door and your thumbs on the inside surface.
2. Rest the hinge hanger so that it is flat (at the bottom of the hinge hanger on the bottom of the front frame slot).
3. Position the door with the hinge hanger slots almost parallel to the front frame.
4. Push up and in until the hinge hanger slots become fastened to the range. Lower the door and rotate it slightly from the front to the back until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front frame slot.
5. Pull door open about halfway and remove the door removal pins. Save door removal pins for future use.
6. Close the door.
1. Open the door half way and install a nail or a screw into the hinge hanger holes on
both sides of the door. let the nails rest against the door to hold the hinges at the proper angle grasp the door on both sides and insert them into the slots and hook the the pins in the slots with the door hinges and let it down open the door all the way and remove the nails that should do it
These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
Whirlpool Supercapacity 465 Oven (RF396 LXE2) Door - c1ea506.jpgmg src="/uploads/images/c1ea506.jpg" alt="c1ea506.jpg" class="h_mi" />
