Amana ale643rbw electric dryer does not advance timer on auto setting. Seems to work on time setting. I can't find a sensor if that is the problem. Thanks
The timer advances when the heat shuts down on auto,if there is no heat the timer will not advance or if the heat doen't shut off the timer won't advance,is the dryer running hot or are the clothes really hot when the load is done on time dryed?could have a problem with the heating element,look at the element to see if it shuts off and comes back on as it cycles on auto?
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
