Belkin (F5D5231-4) Router Logo
Posted on Jan 20, 2010
My belkin g router keeps losing connectivity but my modem is working just fine. I don't get it.
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Jan 21, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
0
Helped
3586
Points
42
Your router could be locking up do to overheating. Make sure it is well ventelated and you can also try to keep a fan on it to keep it cool.
We keep losing connectivity with it. The way I have been restarting it is by unplugging and then plugging in but it now isn't working after doing that. We have had the router for a year and a half. How...
i have a belkin router n 150 .haveing trouble staying on .i keep losing connectivity.i had my internet
check out they said every thing is ok with my modem.thats it is my router.
2 days ago my router seem to lose connection and says theres no modem or internet connection.. and modem is perfectly fine. After i unplug and replug the power, it works for another 5to 20 mins then have...
This is because your router is dropping the connection with your ISP Modem...
It can be even an issue of modem...
To isolate the issue, what you can do is... You can connect your computer directly to the Modem and you can check for any intermittant connectivity...
if you dont have any problem with your modem, then definitely its gonna be the problem with your Belkin Router...
Doing a reset for the router and reconfiguring will resolve the issue in most of the cases...
If in case if it doesnt works, then you can do a firmware update for the router (that would be found in belkin router support website)...
Even then if it is dropping the connection then definitely it is a faulty router...You can ask for a replacement if the product is still under hardware & software warranty...
i work for belkin...
you can reach us any time in 1800-223-5546 if u are calling from USA...
we work 24 X 7....
For any other countries search in www.belkin.com/support
My belkin n series keeps losing internet connection hard wired to my computer and three wireless computers in the house. when hard wired to the virgin broadband modem everything works fine
I would suggest taking a look at your modem LEDs. What happens exactly when you lose connection? A look at the LEDs should give you some thought as what might be causing this. You can also try resetting your Belkin to default factory settings by pressing the Reset button at the back for 30 seconds, and then putting back your Belkin settings.
N1 Vision keeps losing internet connection from modem.
Hi Friend,
Please check it by updating the Firmware for your router from the below website
Regards,
Aysaam
My Belkin N1 router can't seem to establish connection with the cable modem - the router light flashes and connects but as the internet light flashes it loses the router light again. It is still allowing...
the modem is working fine. the connection might be dropping from the router side.
You can try to upgrade the Firmware of the router.
reduce the MTU on the router. If it is on 1500 the reduce it to 1400.
Click Here from more info about routers
Belkin ADSL modem F5D5630au4 keeps losing conection
are you running filesharing? sometimes too many connections at once will cause the modem/router to crash and reboot
2answers
Belkin router keeps losing connection to router
Reset the router and keep its setting default than check it out the problem is same or not...
4 port wired belkin router
Is the cable to your modem in the 'Uplink' or 'WAN' connnection?
Connect your PC to the modem directly. Do you still lose the connection? If you do, Call your DSL tech support and ask them to check the link to your modem. They should be able to let you know if there is a issue from their end.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
