Limescale inside the sprayers, try to remove the sprayers normaly a plastic colar turns then it comes off, give it a shake and it will probly rattle with the limescale in it, i think you can put limescale remover inside give it a shake then put it into a bowl of boiling hot water, be carefull you dont splash yourself, if this dosent solve the problem you may have a faulty circulation pump.
