My bobbin icon is on and I can't reverse sew, and the bobbin icon will not go away, I can fill a bobbin, sew forward, and do nothing else with my machine. Please help!
Its the sensor on the bobinwinder who are loose. If you are handy. you can remove the top cover of the machine.
And on the left side of the bobinwinder you will find a micro switch. Probably you have to tighten the screw on it..
1. Thin material needs backing.
2. Lower foot pressure.
3. Adjust top tension to four.
4. Adjust bobbin (lower) after top tension is adjusted.
5. Increase distance of stitch.
www.manualslib.com > ... > MEMORY CRAFT 4900 QC > User manual Janome MEMORY CRAFT 4900 QC Manual Online: Balancing Thread ... Auto-threadtension When the thread tension dial is set at AUTO for ... to increase the threadtension. ... Sewing Machine Janome Memory Craft 350e Instruction Book.
did you find the tip of the needle? Also you may have a nick in the metal where the needle hit and broke.It can catch on other parts and need to be sanded or replaced.One time I had this issue and I found the tiny broken tip under my bobbin case.
How do i fill the bobbin on a memory craft 1000
