Hi
F1 code indicates an overfill condition which may cause when dishwasher can’t pump out dirty water due to a plugged drain hose.
open dishwasher fully ,dry up as much water as possible then put a hair dryer on hot and direct into the back of the cabinet you will see a grey plastic cover on the bottom floor this is the sensor run on full for about 5 - 10 minutes making sure the heat go into that area. Also don’t overheat your hair dryer, when finished close the dishwasher shut and start your normal cycle.
Thanks for contacting fixya.com
