SOURCE: hp officejet 5510 all in one cartridge error
There are several different ways I've come across which will resolve ink cartridge errors on the HP Officejet 5510.
HP's standard, pat answer to the problem is "Buy brand new genuine HP ink cartridges." If you refill your own ink cartridge or have it done at Walmart or somewhere else, you will eventually run into this problem. Why? Because the 5510 stores information on as many as 2 of the black ink & 2 of the color ink cartridges you have used in the machine - complete with an "expiration" date for each of those cartridges. You can refill them, but unless you clear the stored memory in the printer you probably won't be able to get around the errors. Even if you do, they usually come back in a short period of time. I know this because I own a 5510 & a 5110 and have battled this problem myself for a couple of years.
Short of buying "genuine new HP ink cartridges", using your printer for target practice, or testing it's aerodynamic design... lofting it not-so-gently from a 2nd-story (or higher) window... aiming for the nearest dumpster ;) you might try:
For more adventurous-techie-types, who can't resist tearing into the machine in an effort to resolve the cartridge error permanently, I found the following information posted on a DIY (Do It Yourself) repair forum:
The 5510 has a pair of 1.5v batteries which function much like the CMOS battery on the motherboard of your computer - they supply power to the memory chips which store the serial numbers and expiration dates of the last 2 sets of ink cartridges which were used. The batteries are sealed together at the top and bottom and are attached to a circut board inside the printer on the left-hand side. At a glance, they look a lot like a capacitor or something like that attached to the board. If you look closely, you will see the "+" and "-" markings.
Breaking the connection (located at the top) between these two batteries will clear the ink cartridge serial number info from the printer's memory - but be advised this will probably also clear other short-term memory items also - such as last number redial, etc.
The clever individual who posted this info actually attached wires - one to the top of each of the 1.5v batteries - and ran the wires out through the opening above the paper trays. The wire-ends are connected together - I imagine they would need to be held out of the way of the paper path with a piece of tape.
(M-I-C-K-E-Y...M-O-U-S-E) He, he
When it's time for a cartridge change/refill, the wires are disconnected to clear the memory, then reconnected again after the full cartridges have been installed.
I've read posts from people with different models of printers have mentioned installing a switch to clear the memory - a preferable solution than to have wires running out from the inside of your printer.
This is a widespread issue and regardless of how you resolve the error messages, one must always remember that when you bypass something that is built-into the design of an electronic device, you run the risk of damaging components. In this case, the biggest problem would be running too low or completely out of ink and burning out the print head on the ink cartridge; then you would end up having to replace the cartridge anyway.
Personally, I'm basically fed up with the way HP has been forcing people who buy their printers and All-In-Ones to pay outrageous prices for replacement cartridges, by building machines which generate error messages and reject refilled and non-OEM cartridges. Their drivers and software programs often have compatibility problems even with other HP products which are installed on the same computer with an HP printer. Too many problems for me - I won't be buying any more HP printers and I hear Dell is not much better.
While I haven't tried to jump out the memory on my 5510 yet, that will be my last and final effort before giving it the aerodynamics test... into the nearest dumpster!
SOURCE: poor quality output
Hi If your printer has been left unused for a while your print head is clogged.
You need to unclog it with a print head cleaning kit like Magic Inkjet Flush or if in a rush give it the Magic sauna treatment.
Heres how:
1. Remove print head
2. Hold print head directly in escaping steam from a kettle for 5/10 seconds only
3. Wait 5 seconds and sit it print head down onto a paper towel untill you get an inky foot print.
4. Print test.
5. If any white lines repeat above.
6. Also try wrapping in a paper towel and FLICK DOWNWARDS to put fresh ink into print head after steaming.
Good Luck!
Tinteiros (Ebay)
SOURCE: How to use non HP ink cartridges
only the non hp cartridges which have written the compatibility on it can use with the printer. make sure it has the model number written on the non hp cartridge.
SOURCE: HP K850 cartridge problem
I had the same problem, all cartridges lights came on.
I did two things:
1st: I clean the print cartridges plugs with Q-tips, just to insure there wasn't any ink build on the plugs. If you look were the cartridges are, you will see four plugs one for each of the cartridges. Each plug has four contacts. They should be a bright metal color. If they dull in color, they have ink on them. Unplug the printer and pull all the cartridges out and gentlely wipe the the contacts with Q-tips. Re-stall all the cartridges.
Note: The cleaning did not solve my problem but its good maintenance since in was looking for a solution.
2nd: What work for me was I un-stall my printer totally. Turn off the printer then turn off the computer, had a cup of tea, rebooted the computer and re-install the HP cd disk and drivers, turn the printer back on. After I reinstall the software and put the printer back on my network, everything is working fine for the last two days. The lites are off and the HP toolbox is reading the ink cartridges status correctly. I believe that a virus change the printer drives.
Solution by;
eagleeye140
I have this same problem and some sites said to uninstall the software then download the software from the HP site and reinstall it. So I am giving that a try tonight
I’m happy to assist further over the phone at https://www.6ya.com/expert/barbara_87cfe34e34050f26
