Try reading it in slax linux, mite get some of the data, i got same thing, tried in another shell, no dice, slax can read it for a bit and then gets stuck, i unmount it then mount again, works a little , gets stuck, etc
i booted off usb stick , slax has 200 mb tar file unzip to usb and run bat that makes it bootable
try reading it in slax linux, mite get some of the data, i got same thing, tried in another shell, no dice, slax can read it for a bit and then gets stuck, i unmount it then mount again, works a little , gets stuck, etc
SOURCE: seagate freeagent drive
Hi George,
The seagate freeagent should be reconigized by windows. The question is are you adding an additional partition or do you want to create a brand new partion. I'm assuming you want to add.
You can add more space to existing primary partitions and logical drives by extending them into adjacent, contiguous unallocated space on the same disk. To extend a basic volume, it must be formatted with the NTFS ile system. You can extend a logical drive within contiguous free space in the extended partition that contains it. If you extend a logical drive beyond the free space available in the extended partition, the extended partition grows to contain the logical drive as long as the extended partition is followed by contiguous unallocated space.
Value
Description
list volume
Displays a list of basic and dynamic volumes on all disks.
select volume
Selects the specified volume, where n is the volume number, and shifts the focus to it. If no volume is specified, the select command lists the current volume with focus. You can specify the volume by number, drive letter, or mount point path. On a basic disk, selecting a volume also gives the corresponding partition focus.
extend
Extends the volume with focus into next contiguous unallocated space. For basic volumes, the unallocated space must be on the same disk as, and must follow (be of higher sector offset than) the partition with focus. A dynamic simple or spanned volume can be extended to any empty space on any dynamic disk. Using this command, you can extend an existing volume into newly created space.
If the partition was previously formatted with the NTFS file system, the file system is automatically extended to occupy the larger partition. No data loss occurs. If the partition was previously formatted with any file system format other than NTFS, the command fails with no change to the partition.
Make note of the number of the basic volume you want to extend.
Selects the basic volume, n, you want to extend into contiguous, empty space on the same disk.
You cannot extend the current system or boot partitions.
size=n
The amount of space, in megabytes (MB), to add to the current partition. If you do not specify a size, the disk is extended to take up all of the next contiguous unallocated space.
Notes
Hope this helps!
Thanks
Mark
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
SOURCE: my son knocked the seagate freeagent down and it
Probably bad. Is it not being recognized by your system, no matter what you do?
SOURCE: Seagate Freeagent 1.5TB hard drive beeping
have you ever found a solution? i have the same problem with my seagate barracuda 7200.11 1,5TB
SOURCE: Where get free drivers for Seagate FreeAgent Go
I'm not sure what drivers you're looking for in particular, however, I've found the Seagate FreeAgent download page for you. I've clicked around and all of these downloads appear to be completely free.
These files should be completely safe for download as they are provided by Seagate but don't neglect to set a restore point on your system before downloading and installing. The files are .zip so they must be unzipped, your system should be able to do this without any additional software.
Also, be sure to register your equipment to get customer support should contacting them be necessary. Some of these will require you to contact the company in order to gain access to the download.
Check here:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=freeagent-downloads&vgnextoid=3723b5b59b7d5110VgnVCM100000f5ee0a0aRCRD
