Went to the local hardware and read the labels. The store brand fit and works as good as the original staples. The 1000 has outlasted several of the new fashion staplers. And the local hardware store is an Ace Hardware.
You may find them at True Value, under the True Value Part # 1/4" is part # 659857, 3/8" is part # 660426. You may also find them at Sears under the Sears part number - 1/4" is 74417 and 3/8" is 74418. Swingline is out of business, but these staples are comparable and will work in the Swingline model 1000 heavy duty stapler.
ALSO:
To buy staples for the Swingline Power 1000:
Sears, 3/8” is part # 74418
1/2#” is part # 74419 (In a small red and black Sears Craftsman Staple Package
OR
www.ebay.com or www.amazon.com
Part numbers to search for are Surebonder #5 staples. They are available in 5 leg lengths as follows:
44038 = 3/8"
44014 = 1/4"
44012 = 1/2"
44516 = 5/16"
44916 = 9/16"
They will work!
Thanks ... I will give that a try.
Swingline model 1000 will work with Sureonder #5 staples. You can find them online at amazon.com, also search for FPC Corporation #5 staples. You may also find them in a red and black box at Sears under the Sears part number. 1/4" is #74417 3/8" is #74418, 1/2" is 74419 and 5/16" is 74420.
Go to www.surebonder.com and in the top left corner search for the Surebonder #5 staple. They will work in your Swingline Power 1000 and 34201 stapler. Here are the exact part numbers with leg lengths for your convenience:
44038 = 3/8"
44014 = 1/4"
44012 = 1/2"
44516 = 5/16"
44916 = 9/16"
I have a 115 v Swingline Electric Staple Gun. It is a model 34201. I went to Ace with the gun and could find no staples that had the right width. The width mesures 1/2" and I would like several leg lenths. None of the staples at Ace were 1/2" wide, all were smaller. Any ideas?
34201 also uses the Surebonder #5 staples. Please see above.
To buy staples for the Swingline 34201 & Power 1000:
OR
44038 = 3/8"
44014 = 1/4"
44012 = 1/2"
44516 = 5/16"
44916 = 9/16"
They will work!
44038 = 3/8"
44014 = 1/4"
44012 = 1/2"
44516 = 5/16"
44916 = 9/16"
Www.surebonder.com. Swingline power 1000 works with the Surebonder #5 staple. They are available in 5 leg lengths on that website.
Go to www.surebonder.com and in the top left corner search for the Surebonder #5 staple. They will work in your Swingline power 1000 and 34201 stapler. Here are the exact part numbers with leg lengths for your convenience:
44038 = 3/8"
44014 = 1/4"
44012 = 1/2"
44516 = 5/16"
44916 = 9/16"
