Hi,when i plug in the tv to 220v,the lcd tv will power on but no audio and video on screen please tell me what sould i do. thank you so mush lcd tv model 32lg33r-tc i think the flash ic or e2prom are damage
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
first check the supply of the LCD monitor check the plug supply usually 110V or 220v use a voltmeter, if the voltage is present look for the indicator lights that is changing when power switch is press,the indicators tells you if the problem is in the power supply area of the LCD monitor or in the screen, usually the problem with the LCD monitors is in the screen check the bulb on top of the monitor check if it is not function well this bulb is responsible for the brightness of the screen if it is defective replace it or maybe the supply of the bulb is defective you can use the power supply of the cathode light as a replacement to its supply that is usually use in motorcycles signal lights.. hope this helps you..
Hi , i am babu from bangalore , electronic items servicing person , if your pioneer dvd player problem is not yet solved means & if you are still interested in fixing it means then please let me know - mobile no - 9986222774
Hello shole135, Hi, you need a 110v to 220v step-up transformer with 200 watts power specification. you can visit your local hardware store and find one. Don't replace the toroidal transformer.
Power supply board have intermitten problems,not sustancenig a constance power to the tv.The tv power up 30 mins within the time frame,the tv work than,yes?The power supply board,that the board,where the power a/c coard plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
man firstly use the latest version of power dvd .then try it,if the problem persists than ensure that the lead is plugged in the right place at the tv . remove both plugs one by one reconnect the one for video and plug the other in every possible place.
It is not the power cord that makes the rating of the power supply. You can use a transformer, and not a solid state converter to lower the 220 V to 120 V.
What you will find if this is a North American TV set, it may not work in other countries due to the standards for TV broadcast.
If the set is rated for PAL, this will only work with the video inputs, and not the tuner. The tuner frequency allocation and the video and audio carriers are also different between the some of the different countries.
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Hi, was there a resolution to this? I am experiencing the same problem with LCT3285TA purchased at Radio Shack in Media, PA. Radio Shack has refused to service the unit and has put me over to Akai for the manufacturer's warranty. I'd like to know what to expect and if this problem with the Logo coming up and the unit shutting off/restarting can be easily fixed, thanks.
