Insert it in your pc.
right click after it appears on your computer. and click format or erase.
if these options are not available, delete everything from it.
Clear the memory card by formatting it. Press the MENU button, press cursor-right, select the toolbox icon, press cursor-right, select the memory stick icon, press the button at the center of the cursor pad, then select "Format".
The best and easiest way to clear a memory stick is to format it in your camera using the appropriate command. Different CyberShot models have different procedures for doing this, so please consult your manual.
Empty your trash. If you have deleted saved files and have not
emptied the trash on your device, you have not cleared up any
memory--you have only reallocated it to a different part of the device.
Step 2
Select "Home," "Settings" and then "System Settings" on your unit using your arrow keys.
Step 3
Scroll through your "System Settings" options with the "X" button until you find "Format Memory Stick." Click "X" to select.
Step 4
Choose
"Yes" to confirm that you want to reformat the memory stick. The PSP
will then reformat the stick removing all saved files and reformatting
the stick back to its original memory space.
Step 5
Plug
your PSP or PSP memory card into your computer as another method of
clearing your PSP's memory space. Once you have done so, select the
appropriate drive letter, find the files you wish to delete and delete
them as you would any PC file, or select "Ctrl" plus "A" to select all
files and then click your "Delete" key.
it means it is containing some virus...try to format it with some other system..but it is a frequent problem...try to delete the files while in the phone and format using the computer...its better to claim warranty if it has....
is this cleared your problem?
I am Rob and a expert on camera repair. Please use a universal cardreader they are very cheep and helpfull to clear or format the memory from every brand.
Go into the menu of the camera and look for format under "Memory Stick Tool". Click "OK". It will say "all data in memory stick will be erased". Ready? Click "OK" and it's done.
This camera has both internal memory and allows use of Memory Stick Duo type cards. To format Memory Stick Duo, choose "Memory Stick Tool" and then "Format" from main camera menu, hit "Ok". Choose "Create REC Folder", hit "Ok".
