Electrolux ultra lux shuts on and off every 30 seconds no lights light up bag light etc. its pretty new and hardly used it started doing this about a year after i had it
Try turning the knob on the top of the canester all the way to the right and try it again.Try turning the knob on the top of the canester all the way to the right and try it again.
You can't post conmments that contain an email address.
Need help with the lux 7000, the light "bag full" is on and it will only turn on for 30 second at best. I've put in new bags and the "bag full" is still on. Can you help me
Electrolux uses a pressure differential control valve. This valve measures air before and after the bag. There is a orfice or small hole where the hose connects to the vacuum cleaner, and a orice at the back of the bag canister. As the bag fills up the suction pressure reduces at the hose connection and increases at back of the bag canister. When this happens the control valve has a diaphram that closes, which shuts the vacuum off and gives you a full bag light. There is a thin plastic flange that prevents an o ring on the control valve stem from coming off. The flange breaks, the o rings comes off the stem and the vacuum will shut down indicatiing bag full. The after market price is about 22.00. The valve is easy to replace if you are familiar on electrolux vacuums. When I replace these valves, I use epoxy two part plastic putty on the flange of the valve. It takes 2 days to cure, but the flange will not break.
I had the same problem. I was worried about pulling on the cardboard, that it would break. There is a little yellow lever and I could not understand what it was for. Finally, I decided to go ahead and pull on the cardboard and slide out the bag. It worked. I am not sure the yellow lever does anything, although it might help to push it to the right. The bag slid out and the new one slid in.
It sounds like the valve assembly (full bag control) is faulty. Threr are two O rings inside of it and the plactic holding the bottom one has broken. You'll have to take it to the shop.
This vacuum has a 10 year warranty on the motor, and 5 years on everything else. Look in the yellow pages under vacuums, for the AERUS dealer, that is the new name for the traditional Electrolux company.....
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
i would say it is over heating but some times you cant tell because electrolux have a sensor so when the get hot the turn off till they gool down soo if you really like the vacuum get it look at by a vacuum repair man.
