Timex Lavendar Ironman #T5E971 Watch for Women Logo
Posted on Jan 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't turn off the alarm. Please help - Timex Lavendar Ironman #T5E971 Watch for Women
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Jan 21, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291771
Points
7081
To turn the alarm off press the mode button until alarm 1, 2, or 3, appears (as required).
Press the start/split button to turn off the alarm.
1helpful
C9 champion digital alarm
Since you don\'t know how to turn it off, the alarm will give you simple instructions. Just stop pressing the buttons. Is there a symbol or an alarm or clock on any of the buttons?
May 10, 2013 • Watches
3helpful
Alarm won't turn off on Zoo York watch.
I have a different model but this solution came up in Google and it didn't work. On mine, I tried the following: press MODE. It will show the alarm time. Then press ST/SP a few times until the little alarm icon does not show on the alarm face. If you press RESET instead of ST/SP, it will start blinking and will want you to change the alarm time instead.
Mar 14, 2012 • Watches
3helpful
I have the Speedo Kids Active Swim Watch and cannot remember how to turn on/off the alarm and set the alarm. Please help!
You might find this pdf helpful - it gives a basic description of how 4 button watches can be set.
www.buydakotawatches.com/PDF_FILES/Digital.pdf
Sep 10, 2010 • Watches
7helpful
2answers
Coleman wristwatch - alarm and chime keep beeping
Hey, I had the same problem with my Coleman watch. It would alarm at midnight. I used the mode feature like the poster before me said. When I got to the alarm "screen" I used the button that backlights the watch's screen. The light came on and the alarm feature was removed. I hope this helps.
Mar 12, 2010 • Watches
3helpful
2answers
ADEMCO alarm system indicates A/C not ready. What does it mean, how to fix it?
Turn the alarm off two times. If it still indicates A/C not ready, press the * key and it will tell you what zone is open or what zone has a low battery.
2helpful
Casio edifice mens watch user instructions needed because i can't turn of the alarm and it goes off at half 5 every morning please help
Go in alarm mode by pressing the mode button once twice...depending on the modes you have and then press one of the remaining buttons, usually top right button on most edifices. this toggles between alarm on and off. this shall do....
10helpful
How do you turn off the alarm
What you need to do is hit "Mode" until you're in alarm mode, then hit start until all you see is :00, then if you hit adjust it'll disable the hourly beep. To disable the alarms press the start button until the alarm you want to disable (Will appear on the screen above the mode button) then press but don't hold adjust, the AL1 -5 should disappear from above the mode button now.
57helpful
2answers
Can't turn off alarm
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
May 05, 2009 • Watches
2helpful
How do I cancel the alarm?
Follow this link and find instructions for your watch:
http://www.armitron.com/watch_instructions.asp
Do not forget to rate, please.
Mar 11, 2009 • Watches
5helpful
I have an Athletic Works watch and can not turn off the alarm.
the mode button controls the different functions of the watch.  time, alarm time, stopwatch, timeset, alarmset, in a repeating cycle.  Make sure you are on the time function (seconds ticking and changing every second, but not flashing twice per second.  This is the normal mode that shows the time.
 A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there.  While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator).  Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press.  Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen.  The alarm will now be OFF.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
