Screen and Dashboard lights go dim and bright by themselves whenever headlights are onScreen and Dashboard lights go dim and bright by themselves whenever headlights are on
You can't post conmments that contain an email address.
You have broken vent door on your truck.
Remove the glovebox use flash light to check top of the heaterbox area (top of blower motor housing- toward windshiled area) You will see sponge covered vent.door or you just see outside light)
you can get complete repair kit with necessary electrical actuator about 65/75$ but thing is a job,, basically you have to remove almost whole dashboard to replace them correctly.
good luck.
top dead center
ok look at your damper pulley its the pulley at the bottom of the motor
the damper pulley has a line cut in it
line the mark up with the degree marks
you want to put it on the zero mark
once you have done this you are on top dead center
also number one cylinder must be on a compression stroke
pull spark plug number one turn the motor over with your finger
over the hole when you feel compression that's when you line
up the marks.
It should be. To replace the front shocks, there are two bottom bolts to remove and one nut on the top of the shock. The rears have one top bolt and one bottom bolt. Just regular tools should be fine to do the job. I would also use some WD-40 to help loosen any rusty bolts.
if it's anything like my f-150, lower the tail gate and there will be screws to remove. however, the owners manual will have the procedure. if you don't have a manual, you can download one at dodge.com
