Bulova Watch Logo
Posted on Jan 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Umbro youth watch instructions - my son has lost the instructions. In particular he has an alarm that goes off every hour and doesnt know how to stop it. But any instructions on how to use the watch would be useful. He had the watch for Christmas and must have thrown the instructions out in error.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1955
Points
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Jan 21, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291696
Points
7081
To obtain instruction, go to "boluva.com",
Select your region from the map.
Click on the Boluva picture.
Select "service center" from the menu at the top of the screen and a long list of operating instructions appears. Select yours and download.
Umbro watch instructions
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu:Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Jul 15, 2013 • Watches
2answers
I have an Umbro Youths Black Strap Watch. How do i set the alarm to beep every hour?
Thank you for contacting FixYa.
You can find Bulova instructions here:
http://www.bulovaspecialmarkets.com/service/servicecenter.aspx
Jewel
1helpful
I have an Armitron 40/8125 watch. I try to set the time as follows 1)Hold B - Alarm hours flash 2) Press C - Alarm minutes flash 3) Press C - It goes back to Alarm hours flashing where it should advance to...
You need to press button A to enter the time setting mode and then press C.
If you have lost your instructions, you can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
I lost instructions on how to disable alarm for UMbro digital watch u564b ..can you help?
go to the Boluva site and ask them via the "contact us" option.
100helpful
4answers
Can't figure out how to deactivate the alarm on Umbro U564B watch
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
2helpful
2answers
Setting watch
Press and hold the top left button (mode) until the numbers start blinking. On mine this is the alarm time set. Press the mode button one more time to get to time set. The hour will be blinking. Press top right button (start/stop) to cycle through hour, minute, date, etc. and press bottom right button (adjust) to change the number which is flashing. Press mode to finish.
To turn off alarm, press and HOLD Adjust button, then press Start/Stop to cycle through alarms on/off.
1helpful
2answers
Instructions for ladies' Armitron 45/6974
From the instructions that came with the watch:
Press the button at the top left to get into time change mode, press on the bottom left button to move between seconds, hours, minutes, etc.
Press the top right button to change numbers; hold to move quickly.
14helpful
3answers
Setting a generic one-button digital watch
I too lost the instructions for my generic 4 button digital watch and had to find the functions by trial and error and the results are below.
Adjust Alarm/Time/Date - Press and hold Mode Button. When alarm displays, release. Start-Stop Button SELECTS, Lap-Reset Button ADJUSTS selection. Pressing the Mode Button again changes from Alarm to Time/Date, ADJUST as above. Pressing it again exits.
Select/Deselect Alarm, Hourly Chime or Both - Press and hold Lap-Reset Button, Start-Stop Button TOGGLES through the above options.
Select 12/24 Hour Mode - Press and hold Lap-Reset Button, Mode Button TOGGLES through the above options.
Select Stopwatch - Momentarily press the Mode Button, use the Start-Stop and Lap-Reset buttons to control.
Display Date - Press Start-Stop Button in normal time
display mode.
Display Alarm - Press and hold Lap-Reset Button in
normal time display mode.
Cancel Alarm - Press Lap-Reset Button in normal time
display mode to silence alarm.
Hope this is helpful,
George.
Nov 06, 2007 • Watches
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
