My flash drive lights-up when I put it in my USB port. But a menu does not pop-up when I put the drive in. I can't even find an icon on the bottom right icon line. I need to open files on my flash drive. I have a Acer laptop Extensa 5420/5120 series. Whats going on? Thank you. Mr Chang
Hi, as per ur question asked? it seems that ur flash drive does not get detected when plugged into the USB, there only two causes, either your USB port is not functioning or you flash drive is bad..
Try opening the 'computer' icon - normally shows as an icon on your desktop or in start menu then you will hopefully see the flash drive listed along with C Drive, CD Drive etc. Double click or right click and open - this should let you see and open individual files on the flash.
Boot up your computer and find an open USB port. These are small, rectangular ports typically on the sides or backs of laptop computers, or on the fronts or backs of desktop towers.
Plug your flash drive into the USB port. The drive will slide in only if it is turned in the right direction, so if you have trouble inserting it, turn it over.
Make sure your computer sees the flash drive. It should launch a menu, letting you know that it has found a new storage device. You can choose an option from the menu or close the menu if you don't need to immediately access the flash drive.
Install the flash drive's driver if your computer doesn't recognize the flash drive. The flash drive's packaging should include the manufacturer's website address. Open your Internet browser, go to that address, and download the flash drive's driver from the site. Install the driver on your computer. After that, your computer should be able to recognize your drive.
