Question about Frigidaire FEF336BC Electric Kitchen Range
Frigidaire oven door locked
Frigidaire electric range oven door locked. lock light is on, tried to cancel but cannot. tried to go ahead and clean oven but will not. dont know model number.
  • 4 more comments
  • Anonymous Mar 11, 2008
    Oven door stays locked after self-clean. Tried pressing clear to no avail
  • ughitslocked Mar 23, 2008
    Frigidaire GLEF379DCJ door is locked in closed position. Tried unplugging, pressing clear/off, and turning off circuit breaker for 3 hours. None of the three worked. Tried selecting self clean, but oven will not switch to self clean or any other function except Lock. I can not open the door. Please help.
  • madmondad Dec 15, 2008
    my frigidaire ovev door "auto locked" itself and will not open. I don't have an owners manual, and the useless frigidaire website instructs me to consult my owners manual.
    Please help.
  • Anonymous Mar 16, 2014
    the oven was on and code f4 then code f7 flashed , oven stopped and now has no power.
    It is a small wall electric oven, frigidaire model feb2485sse
  • Anonymous Mar 18, 2014
    I have check door switch
  • Anonymous Mar 23, 2014
    Oven cleaned yesterday and today the oven door won't open. Held padlock in for 3 secs and door locked display came on and then hold it for 3 secs and door open display came on but door did not unlock.
    Novelist:
  • 184 Answers
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
Posted on Apr 04, 2008
6ya staff
SOURCE:
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F9 Flashing on Frigidaire 30" range
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Dec 31, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door locked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$%!!!%!%
Oct 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FES367ABC oven gives f9 error, door lock light is blinking, door not locked. how do i fix
Oct 08, 2009 | Frigidaire FES367 Electric Kitchen Range
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Llock light is on but door will not lock to clean oven
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@$%^&
Dec 14, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door "locked" in open position
Just hold in the oven light switch around the oven door area, then press the cancel button and wait a few seconds.   It will reset.
www.applianceoutletservice.com to chat with me live Bill
Oct 19, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Fridgdaire self cleaning latch
try holding in on the door latch plunger the one that turns the oven light off when you close the door then press start then cancel and inspect the door plunger for any damage
Sep 06, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire---oven door locks.
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
Dec 31, 2007 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire FEF336BC Electric Kitchen Range Logo
1,284 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
