Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Electric fireplace just blows out cold air it is a Century model # is HEF26
    Top Expert:
  • Leisure Master
  • 9,908 Answers
Bad heater element or temp sensor
Posted on Apr 20, 2018
    New Friend:
Clean out the coils real good make sure there is no dust and dirt that will cause it to cut off or not heat up
Posted on Jan 18, 2018
  • 12,061 Answers
It would seem to me that the Thermal fuse has "Blown" this is an internal protection device that operate from heat... they often fail spontaneously, when this happens oftem all else works but no heat.
You will have to take it to a reputable repair shop/man and get a firm "Quote" for repair.
Posted on Jan 20, 2010
SOURCE:
My great world gw2078 is blowing cold air
I would check to see if it has a fuse .
Jan 11, 2015 | World Heating & Cooling
The vehicle is 2004 buick century. sometimes the temp guage rises and comes back down. during this time, clod air blows. sometimes the temp guage is 1/2 way and cold air blows. thermostat has been changed....
is your electric fans running constantly. and most times then not you`ll need a water temp sensor or water temp relay. usually the temp sensor on that model comes usually next to the thermostat with a little wired plug on top. or on the radiator. either way pull the plug while the motor is cold. unscrew the sensor and screw the new one in and replace the electric plug back on top of the sensor. 2 things: Cold motor, have every thing set up and ready because when you take out the sensor the coolant will start to come out. you will not loose much if you work quick. keep rags or paper towels below the sensor to keep coolant off the motor and smelling when it gets hot. you have also pour or hose off coolant after your done installing the new coolant temp sensor.
Feb 10, 2014 | 2004 Buick Century
Elco fireplace blower wont work
If your blower/fan blows air into a "box" with tubes that conduct heated air out through the screen, that assembly may have failed. I had one that burned out and had to be replaced.
Dec 03, 2013 | Leisure HOMEPRIDE Electric Fireplace...
I HAVE A RV WITH AN ELECTRIC FIREPLACE, ITS A HEF26 FROM CFM CORP, DOES ANYONE KNOW WHERE THE RESET BUTTON IS? IT JUST STOPPED WORKING, NO BLOWN BREAKERS
Hi I HAD THE SAME PROBLEM. I TOOK THE electronic BOARD OUT AND FOUND that the main power relay (that's the big black square on the board with the black and red wire connected to the top of it.) solder joints were loose. I bought a cheap soldering gun and resoldered the relay connections at the bottom of the board............Works Fine now................FC
Jan 12, 2013 | Heating & Cooling
Flame has stopped flickering on our Century Heating electric fireplace, model HEF26. Fuses or motor?
Probably, neither. If there's no brightness at all, the bulbs are burned out and need to be replaced. If the brightness is there, but no flickering, then it's probably the motor or the shaft that the bulbs are on is stuck and can't rotate. Really not an uncommon problem with electric fireplaces, no matter who the manufacturer is. If you don't hear a humming noise when the flame function is turned ON. the motor may have overheated and shut down.
To test this, turn the Master ON/OFF Switch to OFF and unplug the fireplace from the wall outlet. Wait 12 - 15 minutes. Plug the unit back in and Turn the Master ON/OFF Switch to ON. Turn just the flame function ON. If it starts right up, the motor has cooled and the unit reset itself. If this continues to occur on a regular basis, contact the manufacturer's Technical Service Dept. If nothing happened after it was turned back ON, contact the manufacturer for replacement parts.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 04, 2011 | Heating & Cooling
My electric fire is just blowing cold air?
It sounds as if the heating element has burned out (which is very common with electric fireplaces) or it overheated and the overload switch turned the heater off. Since you didn't mention who the manufacturer of your fireplace is or the model number, it's hard to make any suggestion on how to solve the problem. Other than one: Turn the fireplace OFF, unplug it and wait 30 minutes to plug it back in and hopefully, it will reset itself.
Mar 02, 2011 | Heating & Cooling
The air blowing out is cold and not heating up...
Your electris heat strips are not being energized. need to look at fuses and wiring.
Oct 26, 2009 | Leisure HOMEPRIDE Electric Fireplace...
My electric fireplace model # HEF33WDG, the heat works, but the flames dont move. Can someone help me.
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
Oct 21, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heater blowing cold air Buick Century 2000
does the car not heat up in general? Whats the temp gauge doing and how long of a ride have you tried this for?
Jan 04, 2009 | 2000 Buick Century
Heating & Cooling Logo
1,199 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
