If you're using an indoor antenna (rabbit ears), you'll find that there's little difference between them. Yes, you'll see all the fancy knobs, but mostly all they do is delay the signal from making it to your antenna jack, hopefully enough to reduce ghosting on analog channels...or a resistor circuit that reduces the signal strength. Receiving a good signal with an indoor antenna can be difficult...there can be obstacles between your tv and the broadcasting station, you could be too far away...it's hard to tell. Before you use an outdoor antenna (consider a good RV antenna if you need to use it indoors), try an antenna amplifier. It'll have to handle both VHF (at one time channels 2-13) and UHF (channels 14-69 analog). If it's an "antenna amplifier," it will be sufficient. If it's a cable amp, it would be a hit-or miss. The amp may be able to boost your signal with the indoor antenna you have now. Alternately, you can buy an indoor antenna with the amp built in. Hope this helps.
