Dishwasher starts but after what sounds like a pre rinse it won't continue - it sounds like it is stuck - just a low constant sound or tone is heard.I turned it off at wall and turned it back on but still had the same problem. I have also cleaned filter to see if anything is stuck inside but there wasn't. Please help.
This sounds like the anti flood device has activated (due to some water on the bottom base of the washer) This device shuts of the water inlet and puts the pump out motor on (the sound you are hearing). Nothing els happens until the water on the base is dried and the faulty pipe / leak rectified.
The anti flood device is a small polystireene plate connected to a micro switch on the bottom of the washer.
Hi
Thanks for using FixYa. If the cycle doesn't
complete, then the first thing that should be checked is the Timer and then the
heating element. Timers don't often fail. But if every other part of the
dishwasher seems to be working properly and the timer knob seems to be stuck in
one place--doing one function continuously--the timer may be at fault.
Dishwasher timers can't be repaired. If yours is defective, replace it. Many
dishwashers heat the wash and/or rinse water to a higher temperature, as the
cycle calls for it. In these cycles, the dishwasher pauses after it has filled
with water, waiting for the water to reach the pre-set temperature. What
happens next depends, as follows: On some units, the pause is timed and the
unit continues after the allotted time. On others, the cycle can't continue
until the water reaches the higher temperature. If you have this type of
dishwasher and the water isn't being heated (say, because of a problem with the
heating element or thermostat), after the unit stops at the heating cycle, it
never continues. When you repair the heating-system problem, the "cycle
problem" is fixed too. Please accept the solution if the
issue is resolved or post a comment for further assistance.
Thanks
Rylee
