I have a Minolta EP 1083 the copies that it gives arn't very well fixed and can be smudged by rubbing the copy with your finger. The fixer lamp is still working but the machine was coming up to the point where the starter was due to be renewed. I have tryed to do this as per the owners manuel and nothing happens when I switch the machine on, does anybody know how I get the copier to accept the new starter.
If fuser rollers are getting hot - you either lack pressure between upper and lower rollers Restart; remove/dump old developer - instal correct compatible starter reinstal imaging unit remove toner ctg. key in stop 0 stop 1 tec rep run F-8 mode runs apx. 2 min. exit svc mode If whats not fusing is gritty(starter) - other issues
