Re: An error message comes up and I get knocked off the...
It Just tells me that microsoft has encounted a problem and must close then it kicks me off and ask me if I want to send an error report which I have done several times. Thank you dog lady
Error messages can mean several things. You may have lost internet connection for a short period or your tablet may be having problems with downloading. This is a common problem that happens to devices if they aren't working properly with internet or you could have interferance. Try down loading later at night, late late and see if it just happens to work.
If the knock sensor isn't working it isn't a real problem IF the engine isn't knocking. The sensor detects the faint pinging that comes before engine knock and sends a signal to the ECM which then begins to ****** timing until no pinging is reported by the sensor. If you do have knock and the sensor isn't working you can severely damage your engine.
Sorry I know very little about the dvd side but my experience with several VCRs is they need cleaning sometimes just like audio tape recorders and players need cleaning. Early in my days of VCR ownership the engineer I used was sick of seeing me and taught me how to clean the heads, guides and rollers myself to restore performance and help prevent tapes being chewed. Head cleaning tapes simply did not reach the parts needing cleaning though the the wet type sometimes helped.
A VCR might work normally for several months and then suddenly it would happen again. Sometimes I needed to do a clean several times in a month. I did have a Sharp VCR once and that had something called an idler reel that would "suddenly" need replacing (several times) due to chewed tapes but other than that manual cleaning did the job every time.
Later VCRs were fitted with a self cleaner that worked well and meant there was no trouble for a long time but when the self cleaner became loaded with filth they actually made matters worse.
Matter of interest, I use clean newspaper and methylated spirit for cleaning.
Dear Sir the Fault you have is all about your Dynamic Stability and Traction Control.The sensors fitted on your wheels which are checking the wheel speed usually get gummed with road dirt and debris and cause error to trigger. Ask Volvo mechanic to clean the sensors and the problem would resolved.
There can be several issues. I suspect virus attached to rootkit. First, check if your computer has all the necessary updates. Second, scan it with antivirus program for viruses and malware(can be that they are clogging your computer and connection. I recommend NOD32 and MalwareBytes.
i've tried (for several days now) to download the software, but everytime i click "download & play" nothing happens
(it looks like the 'page' just keeps refreshing it self for several minutes, ending in a "error code 357" message!
I contacted skillground numerous times , and thou they are helpful in
their replies.. they keep saying that its my router and/or firewall
that prevents the software from downloading.. BUT
even when i disable the router (running the internet cable direct
from the "wall plug" into my pc) , and disableing my firewall (Norton)
(i have even tried uninstalling the Norton).... its still the same
problem
I've allowed cookies... set the internet security to minimum
..disabled the router and Norton firewall, ..removed the skillground
'program' and even tried to create another account ...but its still the
same problem ... so i've ran out of idea's
but have you tried checking (in addition to your router, and norton firewalls) the built-in vista firewall?
First make sure that you do not have the collate and staple option checked on the printer menuing system or in the print setup on one of the local machines printing to it. Ensure that when auto-staple is not used that the error stops manifesting.
Then, I would check to make sure that you are installing the correct staples, length and width for the model.
