Washing Machines Logo
Posted on Feb 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing machine making crackling noise when spinning
as i said my washing machine making noise when its spinning.
noise is like bearing crackling.
  • 2 more comments
  • Anonymous Aug 16, 2008
    When I turn on my washing machine and it begins to wash, I can hear a crackling sounds coming from the back, almost like coming from the pipe that the water pumps out, it also crackles throughout the cycle. Not sure what this could be?
  • Anonymous Mar 19, 2014
    not doing anything just making a noise
  • Anonymous Mar 24, 2014
    maytag washing machine makes screeching noise when spinning water out
Anonymous
Level 3:
  • Master 958 Answers
  • Posted on Feb 12, 2008
Anonymous
Master
Level 3:
Answers
958
Questions
11
Helped
445064
Points
2548
Check for some loose items underneath the unit. washing machines normally reverses its rotation when spinning. check if mechanical solenoids pulls the right levers as it starts to spin....
Fisher and Paykel front loader grinding noise
There could be a few possible reasons for the grinding noise in your Fisher and Paykel front loader washing machine. Here are a few things to check:
  1. Check the drum paddles: If the drum paddles are worn or broken, they can create a grinding noise during the wash cycle. Check to see if any of the paddles are loose or damaged.
  2. Check the drum bearings: The drum bearings are responsible for supporting the drum and allowing it to spin smoothly. If they are worn or damaged, they can cause a grinding noise. To check the bearings, try spinning the drum by hand. If it makes a grinding noise or feels rough, the bearings may need to be replaced.
  3. Check the drive belt: If the drive belt is loose or worn, it can cause a grinding noise. Check the belt for any signs of wear or damage, and make sure it is properly tensioned.
  4. Check the motor: A faulty motor can sometimes cause a grinding noise. If you suspect the motor is the problem, it's best to call a professional for assistance.
If none of these solutions fix the problem, it's best to call a professional to diagnose and repair the issue.
My LG Front Load washing machine is making a grinding noise on spin cycle I believe it is coming from the motor
Hello. The noise you are hearing on spin is a failed basket support bearing. Depending on the model, you are looking at a cost of a professional to repair it of around $400+. If you do it yourself, around $200. This is a common failure on LG washers.
1helpful
Indesitw123 front load washing machine making very loud noise when spinning
The noise you can hear is the drum bearings, the seal between the drum and bearings has failed and let water into the bearings which has destroyed the bearings.
Hello, my washing machine is making a very loud noise, even louder when spinning?
the drum bearings are bad,it costs anywhere from $400.00 to $900.00 to replace them and possibly more if you need to replace the inner tub with the bearings
1helpful
Hello my Wirlpool washing machine makes a scratching noise when the drum is turning during the wash. The noise disappears however when the washing machine is spinning. Would it be worn out bearings?
You would hear the bearings in the spin cycle if it was them ....it would sound like you are at the airport...you will probably find that a bra wire has caught itself inbetween the drum and the tub and is scratching as it goes around.
2helpful
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
1helpful
My Ariston A1636S Is making a very loud crackling or rattling noise when it spins. Almost like something is loose inside it. I've checked and nothing has fallen into the drum. Can someone help?
Remove the dive belt, and spin the drum by hand, if it feels rough or is noisy, then the main drum bearings have failed, if no noise, then look elsewere.
Please rate my solution.
Thanks.
Washing machine making whining noise during spin only
Its a bearing on its way out. the seal is also probably worn.
5helpful
2answers
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Top Ariston Technologies Washing Machines Experts
ZJ Limited
ZJ Limited
vince
ADMIN Andrew
ADMIN Andrew
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
