Not collecting water,cleaned filter
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: our Whirlpool gold dehumidifier is leaking water.
Do you use a hose with your dehumidifier? Could it be leaking? I have two machines in my basement. I use hoses on both. I had to do funny stuff to make the hoses not leak on the plastic 'blown' tanks. Even the cap that originally came with the machines were leaking before I started to use the hoses.
Check for holes in the tank as well.
SOURCE: whirlpool dehumidifier ad35dssi runs, but
Glad to hear that you thought to clean the filter, as that would have been one of my suggestions. Because, it's the most overlooked.
But, there is another one that equally overlooked and is probably the number cause of your humidifiers problem. The humidity extraction level is set to HIGH. Lower it to 32 - 35%. If your unit does not have an LED Screen readout, set the control on MINIMAL.
This is what gets confusing about the use of dehumidifiers. They work backwards from what most people think. The lower the setting, the more moisture/humidity is extracted from the house. The higher the setting/numbers, the more humidity remains in the house. The higher setting would be used only in the Winter, because removing all the moisture and humidity will make the house uncomfortable.
If this wet area, you mentioned is a basement. The ambient air temperature at floor level is colder than at chest level and dehumidifiers don't work well in temperatures between 40 & 60 degrees F.
If this is the case, placing the unit up off the floor on a sturdy table, counter, etc that can hold the weight of the unit, plus a full bucket of water will generally solve the problem.
Also, be sure that you're maintaining at least 12" of clear air space on all sides of the unit. If the air flow is obstructed, the unit will run all day and not extract any water.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Testimonial: "Thanks! We'll give it a try. It's running very "quiet"too, and I see from my searches that it could be the condenser, etc, We'll See!"
SOURCE: First the dehumidifier Gold AD35USS1
Brisy, you have an electrical problem within the unit, which may require the help of Whirlpool Technical Service to solve. That is, unless you have a multimeter and want to dismantle the unit to find the electrical problem. Could simply be a shorted wire or something more serious, which could require replacement parts. Also, consider the age of the unit and would it be cost effective to repair it, as opposed to replacing it. Quite honestly, repairs, sometimes can cost almost as much as a new unit.
Hope this helped you. Please let me know.
SOURCE: i have a whirlpool dehumidifier model # AD25DSS1.
How can not get water to flow from the bucket through the water hose when the hose is attached.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
There
Here
Dehumidifier
heatman101
There
Here
Dehumidifier
heatman101
