Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
My Hotpoint Aquarius WD61 will run for a will on drying cycles, spins or washes. However after about 15 to 30 minutes the machine trips the fuse at the fuse box. After resetting the fuse the machine will then trip the fuse instantly on any type of wash, dry or spin cycle.
Once left for an hour or two you are back to square one were the machine works for about 15 - 30 minutes.
I have checked inside & out and their is nothing obviously wrong. Any help would be well received.
I had this problem, the fault was a power wire near the top rubbing against the metal and causing a short, you wouldent have seen it without checking the loom carefully and seeing the insulation worn awayI had this problem, the fault was a power wire near the top rubbing against the metal and causing a short, you wouldent have seen it without checking the loom carefully and seeing the insulation worn away
You can't post conmments that contain an email address.
The issue with the Hotpoint Aquarius WDL540 Washer/Dryer tripping the electricity during the fast spin cycle could be due to several factors. Here are some steps you can take to try to resolve the issue:
Check the drum balance: Make sure the load is evenly balanced in the drum. If the load is unbalanced, it can cause the drum to spin unevenly, which could trip the electricity.
Check the motor: If the motor is not functioning properly, it could cause the machine to trip the electricity during the fast spin cycle.
Check the belt: If the belt is loose or damaged, it could cause the drum to spin unevenly, which could trip the electricity.
Check the suspension: If the suspension is worn or damaged, it could cause the drum to spin unevenly, which could trip the electricity.
Check the wiring: If the wiring is damaged or frayed, it could cause a short circuit, which could trip the electricity.
If you're unable to resolve the issue with the above steps, it's possible that the machine may need to be repaired. In this case, you may want to consider contacting Hotpoint customer support for information on repair options.
If it is tripping the breaker, the first question that has to be asked is how many other appliances do you have on the same circuit. When the washer goes to spin it will start to draw slightly more electricity than once its at a full spin(much like the energy needed to get a car moving is greater than once it is up to speed), but it is not enough to trip the circuit unless there the circuit is already near capacity.
Before attempting to check electric of the washer, check and remove items from the circuit. To know what circuit runs your washer you will need to take a pigtail or a radio and plug it into the outlet Go to circuit breaker box and turn on and off circuits until the radio goes out.. Once you acertain what circuit your washer is own, go throughout the house and see what circuts are shared with the washer. Unplug any that are shared with washer. Your Hotpoint needs no more than 15 amps to run but if your overloaded on the circuit, the spin is enough for it to trip the circuit. Try washer and see if you go through the full cycle.
Are you around when the breaker trips? It almost seems as though an electrical connection is getting wet. Especially if it won't let you reset the breaker. Another reason for not letting you reset the breaker could be an overload that tripped but that to me would be within the machine, it shouldn't trip at the panel. You get pull the machine apart and check for these things. Look for and wetness or wire connections being crossed, anything like that. Something at the spin cycle is shorting out and tripping out your breaker. Also is your dryer circuit properly sized (30AMP Breaker with 10/3 wire)?
If you've just installed it for the first time ensure that transporting locks been removed (big screws under usualy yellow or white plastic covers at the back side of the machine) Make sure that machine is standing flat on the floor with no swinging whe you try to move it, this can be achieved by adjusting four legs of the machine (one at each corner). If neither of those helps than you need to identify when the noise appears what machine is doing at that moment. If the noise appears when it's draining, pumping water out, than your machine's pump is wearing out, or if it's noisy when spining (final spin) than bearing of the drum is wearing out.
it's possible that one of the carbon brushes have worn down to the bottom and it is sparking on the motor causing it to trip the fuse. It's just one possibility. Have you checked the carbon brushes are connected properly and that they have not 1) worn down and 2) that the wires are connected to them correctly.
I believe the problem is in the fus(breaker). I would say that it is the thermal fuse in the machine but it usually goes out before the breaker does. The breaker has gotten weak over the years. You have a hi limit on the machine as well but I doubt this is it. Let me know how you do.
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
clothes not very dry after spin
