I'm to facing the problem of DCP 8045D LCD Display says Hex Dump mode ....it occurred after paper jammed while Xeroxing ..I don't know how to factory reset my DCP 8045d ...while printing with computer ..printer goes on printing in hex code ...it means fuser is ok pl. help regarding the problem ...Thanks UmeshI'm to facing the problem of DCP 8045D LCD Display says Hex Dump mode ....it occurred after paper jammed while Xeroxing ..I don't know how to factory reset my DCP 8045d ...while printing with computer ..printer goes on printing in hex code ...it means fuser is ok pl. help regarding the problem ...Thanks Umesh
Re: DCP 8045D Display says Hex Dump Load - What does this...
I resolved the " Hex Dump Mode" problem Step1: switch off power Step2: press and hold Stop/Exit ( Red Color Key ) switch on power supply ....... now no " Hex Dump Mode" problem
Probably the easiest way to turn off the Hex Dump mode would be to reset all printer settings. There should be a reset menu that will allow you to reset the printer to factory defaults. After which it should recognize the new ram and print normally.
The document cover (or lid) is the large part that you pull up (open) when you want to scan a single page using the "flatbed" part of the scanner instead of the automatic document feeder (AFD).
There may be something under the lid that is holding it up slightly open.
Lift the lid and close it...
It should work, now.
If NOT, Turn OFF, unplug from outlet, wait a few minutes and plug back in.
I resolved it by pressin& Hoding Stop/Exit key before power on
