Polaroid i1035 Digital Camera Logo
Posted on Jan 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The date and time will not stay after setting, is there a flash update?
Anonymous
Level 2:
Sniper:
  • Expert 109 Answers
  • Posted on Jan 23, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
109
Questions
11
Helped
275963
Points
312
This is a firmware glitch. If you disable the startup image, the date and time is not saved. To fix this issue, you must re-enable the startup image.
Turn on the camera and press Menu (M). Press the right side of the circular directional button to select the wrench. Press OK/Edit.
Next, navigate down to "Opening" and press OK/Edit. Select ON and press OK/Edit. Go back up to Date/Time and set the date.
Restart the camera to see if it works.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Jan 19, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200798
Points
38521
When you finish putting in all the data, press the set or ok button twice.
I received the new telkom 3GFLLA wireless phone - how do I set the date and time?
In standby state, enter [Menu] ? [Settings] menu.
:6.1 Phone Settings
6.1.1 Date & time
1. Set time: Set the time of your phone.
2. Set date: Set the date of your phone.
3. Time format: Select from 12 hours or 24 hours format.
4. Date format: Select from [Year-Mon-Day] or [Mon-Day-Year] or [Day-Mon-Year]
5. Update time settings: Set your time to [Auto update time] or [Manual update time]
Phone will not hold time and date
Change the setting in your settings. It's in manual mode. Change it to auto time update
I can't figure out how to set the time and date on the HEM7300REL blood pressure monitor. I have a manual and have followed the instructions without results. I don't see a reset hold on the machine. do...
If you remove and replace your batteries...you will not lose the memory. The unit will store up to 90 measurements in non-volatile memory...so it will stay there.
I have the same unit and use these directions....and never had issues with setting the date and time.
2.2
Setting the Date and Time
Your blood pressure monitor automatically stores up to 90
measurements values with the date and time. To make use of the
memory and average values functions:
• Set the unit to the correct date and time before taking a measurement
for the first time.
• If the batteries have been removed for more than 30 seconds, the
Date/Time setting will need to be set.
1. Press and hold the Date/time
setting button (
) to adjust the
date and time. The year digits
(2008) will flash on the display.
2. Press the Memory button ( ) to
advance the digits one at a time.
Notes:
• The range for the year setting is
2008 to 2030. If the year
reaches 2030, it will return to
2008.
• If you hold down the Memory
button ( ), the digits will
advance rapidly.
3.
Press the Date/time setting
button (
) to confirm the setting
when the desired number
appears on the display.
The year is set and the month
digits flash on the display.
4.
Repeat steps 2 and 3 to set the
month.
The month is set and the day
5.
day.
The day is set and the hour digits
6.
hour.
The hour is set and the minutes
7.
minutes.
The minutes settings is set.
button (
) to turn the monitor
off.
When adjusting the date and
time, press the Date/time setting
button (
on, follow the steps above, and press the START/STOP
button to turn the monitor off.
Good luck.
Semper Fi,
Z
1helpful
Date and time will not stay correct
Is it set to auto update from a time server? Right click on the clock in the taskbar, select adjust date/time. On the internet time tab, click advanced settings. I would recommend using time-a.nist.gov instead of time.windows.com
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
1helpful
Clock and date
Hi there.
Download the latest bios update for that model motherboard or PC, install it and restart the PC, time and date should stay once set .
Good luck and thanks for using FixYa!!
Camera will not keep date settings
I suggest u to contact the service people and they will change the internal battery to keep update with time and date. Every camera has internal small battery so has to change regularly
58helpful
7answers
Cannot set the date on my Canon P23-DH V calcualtor
ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
2answers
Clock radio, small
This little guy has the most complicated date setting procedure I have ever seen! From the manual: "Manual Time and Date Settings 1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing. 2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator. 3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting to lock into place. 4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year. 5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the 4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day. 6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place." You can download the manual from the link below: http://www.timexaudio.com/pdf/T307_IB56281_07.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
