Washing machine goes right thru a normal cycle but when it reaches the drain/spin it stops makes a humming noise and bleeps on digital panel saying ERR2, water wont drain and machine wont spin although the drum spins round as normal during the wash cycle it wont actually go into a full fast spin or drain
It will not spin with water in.
See if you can locate a filter, and clean same.
Err 2 means water hasnt drained within 4 mins - this is either because there is a blockage or your pump isnt working. Turn off power and unplug before starting You may have to drain machine by hand and check the filter. The filter is found at the bottom right hand corner on the front of your machine. Unscrew (bearing in mind there will be a lot of water behind it) and remove and check if it is blocked. You should also be able to see the green pump rotor which should turn freely when pushed around. Hope this helps.
Your drain pump is bad. It will not spin with water in it. Replace the drain pump, it is easy to swap out.
