The Nortel 7316 set is propriatary which requires the nortel system in qrder to work., The pulsing lights are the set reacting to the standard line voltage.In order for it to work in your house you'll have to install the nortel phone cabinetand then attach the set(s) to it.
Message to Logan360, The reply to your posting was correct - the phone needs to be connected to a Nortel KSU to operate. I read this while looking for a used (good) (cheap $ - as I am just getting started working again after health problems) T7316e phone to use as a test phone. I am not certain you still have the phone - or if what you did to it will leave it able to work "right" If you do have the phone - will you send me an email?
Thank you
[email protected]
Follow this instructions to reset the Administrator password.
Press Feature 985 and dial 9 even though it is not listed as an option.
The display will show Pswd: dial 73738767793
The display will show Reset pswd? Press YES.
You should now be able to enter the default password.
2 digit extensions use 120000
3 digit extensions use 1020000
4 digit extensions use 10020000
