Yes the capacvitors on the power board can cause the red lamp light and a 34 error code. The V26 Power repair kit from www.tvrepairworld.com will usually solve that issue. The kit contains the upgraded caps and the CD with instructions for the repair.
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
Here's something that might also be useful. After you turn on
the set, and get the regular red blinky lights, hold down the Device
and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
