HP Pavilion a1253w Notebook Logo
Posted on Jan 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp pavillion a1253w-power light (green)flashes and computer will not turn on. I removed all connections to power supply, then replaced one by one. The light did not flash, but the computer did not power up either. Further, when the main power (P1) supply to the mother board was connected the light flashed and the computer will not turn on. Is this a mother board problem? Please help.
electronic & computer repair& servicre
Level 3:
  • HP Master 12,061 Answers
  • Posted on Jan 19, 2010
HP Master
Level 3:
Answers
12061
Questions
0
Helped
4007585
Points
36390
Could be but try a replacement PSU first.
HP Pavillion a1514n Won't Turn On
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
2helpful
2answers
Power light on computer flashes..tried the trouble shooting advice w no results. Bestec power supply model atx 250-12z. Unplugged computer to clean and now wont turn on..No fan no nothing..Just a green...
If you didn't accidentally unplug the four pin connector near the CPU, you need to replace the power supply. This is actually a fairly common occurrence with the cheap ATX power supplies being tossed into systems these days.
I have a HP/Compaq 6510b laptop computer and it will not turn on...I have the charger plugged in and the only thing happening is the green light periodically flashes...Is the battery bad?
IF the battery is bad the charge lndicator on the laptop will flash (But not periodically) it will be a constant on-off-on-off..... Best check would be to remove the battery completely and use the adapter/charger power supply only. If it still does not turn on then you either have a bad power jack connection or a more serious motherboard problem. Also is the green light flashing on the adapter/charger or is it the charge/battery indicator on the laptop?
Power supply light flashing green ,,, tried unplugging mother board still flashes green is it the power supply or the mother board?
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Computer will not turn on....how do I check to see if power supply is faulty? I have power supply removed and have a tester to check for dc voltage etc
I just went through a heap of troubleshooting with power supply issues before swapping psu's and finding this was the solution to my problem. Had a closer look at my psu that was faulty, the green light was flashing on the psu, unplugged all components and thought that I now had a non-flashing green light on my psu, on closer inspection the light was actually flashing very fast so appeared to be an almost solid light...the psu was stuffed so replaced it and no more issues. If your power supply has a green light check to see if it is flashing when plugged into voltage with nothing connected to it. If it is a solid light then it is probably ok.
Computer Will not start with my new pci device
Remove the card and install again making sure it goes all the way in..( and/or installing on another slot.. Make sure theres no hair or dust goes in the slot.. If problem persist, 1. You probably need to access bios n configure/enable the pci ports.. 2. The power supply is insufficient.
2helpful
''My HP Pavillion ZE5300 Laptop Doensn't Come On At All!''=v.v=
when you press the power button, does any light flash for 1 second?
remove the memory, hard disk, cd writer from the laptop. then try to switch on again. do it using the power adapter.
if it doesnt come on then its an internal problem. you will have to open the laptop case and remove all parts for test
good luck
Posible bad power supply try using another power supply.
3helpful
Power supply light flashing.
Computer power supplys are modular replacement fixes. Better to replace the whole thing then try to repair.
1helpful
2answers
Power led flashing...
The described problem might not be the Power Supply Unit, there are a number of different reasons that may cause this symptom. Consulting HP would be advisable.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
