According to Shaw.ca there are no codes for Nova. You can try doing a code search.. follow this link to shaw remotes, click on your remote and do a code search.. good luck! http://www.shaw.ca/en-ca/CustomerCare/TelevisionSupport/UserGuides/RemoteControlCodes.htm
Right click on your internet connection logo (2 blue monitor screens) in the System Tray and select "Diagnose and Repair" No Problem? proceed. Internet Explorer is used to sign into Yahoo Messenger. If you have another browser set as default IE will still sit as a link between your browser and Yahoo Messenger. For this reason most troubleshooting is concentrated on Internet Explorer.
Try each of these in turn, and try to sign in after each of them - if successful (or not) please feed back information to help others.
1) I would recommend installing the latest version of IE and update any support software (Flashplayer, Java, Shockwaveplayer) for IE by using an update checker http://www.filehippo.com/updatechecker/ 2) Start with a clean browser Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors. http://www.filehippo.com/download_ccleaner/ 3) On the sign in page click 'Messenger' > Connection Preference Toggle between 'Connect direct to the internet' and 'Proxy setting' make sure the information is correct in the lower 2 boxes. I am currently in the Asia Pacific region and I have to toggle between these settings a few times a week to maintain my connection 4) Check these settings in IE (even if you have another browser set as default) a) Tools > Internet options > Connections > Lan settings > check 'Automatically detect settings - uncheck other options. b) Tools > work offline - make sure this is NOT checked and has a red X through it 5) Disable your firewall and do a trial sign in 6) Control Panel > Internet Options > Connections > LAN Settings-uncheck Proxy server and check automatically detect setting 7) Control Panel > Internet Options > Connections > dial-up and virtual private Network setting > select your default connection > setting > check automatically detect setting 8)If you are unable to sign into this secure page (https) https://login.yahoo.com/config/login?.src=fptx._intl=uk copy the yahoo https address above and paste it in here:- IE > tools > internet options > LAN settings - check automatically detect settings > Advanced - paste in 'Secure' window > OK 9) Run ccleaner again
No. If you see that the bulb was burned, you can replace it yourself, you dont need to take off the battery terminal since taking it off might cause more trouble to your car. dont worry you cant be electrocuted by a 12V dc by just replacing the bulb
Your problem is with your graphic card.
Seeing that it shows an error of pixel shader 1.1 i can only guess that either you are using video card provided by compaq.
Only solution get a good graphic card.
I suggest one from nvidia.
You need to have a card with Pixel Shader 2.0 and above, like the nvidia geforce 6600 GT, 6600 or 6600 le. However, those cards are PCI Express cards. If you have a AGP slot, look for any AGP card with Pixel Shader 2.0 and above.
Cheers
