Sync up? Do You mean instructions for connecting the scanner to the computer and scan?
Try re-installing the drivers from the link below and try scanning again
http://onyxftp.mykonicaminolta.com/downl...
Install the first one. It is the latest universal driver.
KM UniversalDriver ps v1210 win2kx vista xp English.zip
MD5
First you have to un- install the previous driver though,and then instal it. The easiest way to fix the issue.
Assuming you have the scan chip on your C250...
on machine touch the following
utility
one touch
one touch
new
touch smb/pc
touch name and enter a name
touch down arrow (go to page 2)
touch reference
touch either the domain or the workgroup your computer is logged into
touch open
browse to your computer
touch open (after highlighting your computer)
If user id/password blocks pop up then enter the name and password that you login into the computer with
browse for the folder you want to use.
then hit ok
this takes you back to the page 2 screen with everything set for you.
hit ok then hit close until you are back to copy screen and try.
This is the steps I use and it works 99% of the time. Also if the system admins have turned smb protocol off then you cannot use it. You will need to use another method.
Hello.
There is a USB port to connect the C250 directly with a USB cable. Then, install the C250 driver on your computer with the CD that comes with your C250.
Hope this helps.
There is already an address set in the machine in the address book, and the scanner used to be able to connect with it. When I changed the name of the desktop on my computer (I took over for someone else), the address would not connect anymore. I think there is a way to change this online, thereby updating the address on the machine.
The computer and scanner used to synch up just fine, but when I changed the desktop name on my computer, the address in the bizhub system won't connect anymore. It was all done without having to plug in a USB cord.
There should be an easy way to fix this on the Konica Minolta website...
Yes, it used to work, but I took over the computer from someone else and changed the name on the desktop. Now the address that we already have programmed in the bizhub won't connect because it doesn't match up with the name on the computer.
There are more than 400 files there...which one do I download?
