Gaggia Expert
- Posted on Mar 05, 2010
Re: Gaggia syncrony logic not dispensing water. Just...
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
The wand would dispense water for a few seconds and then shut down, complete with red light. If by descale the boil coil you mean run descaler throught the actual coffee maker part and not just the wand like it says in the directions, then we did that.
Major scale had clogged the water lines from the pump, and descaling seems to have solved the problem for the most part, although the knob that regulates the quantity of coffee dispensed no longer works (just keeps dispensing and doesn't respond to any adjustment. If we turn it all the way down it dispenses a half cup), and there seems to be more water than usual in the dregs box.
I can live with all this as long as it doesn't indicate something about to go seriously wrong, and I would love to know how (if) it is related to our initial trouble. For the record, we have sworn an oath never to use our tap water in the machine again. It is the hardest water on earth.
Thanks for your help! LG
p.s. come to think of it, the water/steam from the wand still does seem a bit off. It works at first, then peters out.
Thanks, I'll try the grease. Especially since I have had to clean the brew unit so thoroughly.
have you descaled the boil coil?
do you get steam out or hot water out the wand?
gbw
